Ir para o conteúdo principal
Acer Nitro 5 AN515-55-53AG Internal Fan Replacement
O que você precisa
  1. Acer Nitro 5 AN515-55-53AG Internal Fan Replacement, Fan: passo 1, imagem 1 %32
    • Prior to beginning, be sure to turn off the device and unplug it from the power source.
    • Set the device on a flat surface with the vents facing upwards.
  2. Acer Nitro 5 AN515-55-53AG Internal Fan Replacement: passo 2, imagem 1 %32 Acer Nitro 5 AN515-55-53AG Internal Fan Replacement: passo 2, imagem 2 %32
    • Use your Phillips #0 screwdriver to remove the eleven screws holding down the laptop's bottom cover.
  3. Acer Nitro 5 AN515-55-53AG Internal Fan Replacement: passo 3, imagem 1 %32 Acer Nitro 5 AN515-55-53AG Internal Fan Replacement: passo 3, imagem 2 %32 Acer Nitro 5 AN515-55-53AG Internal Fan Replacement: passo 3, imagem 3 %32
    Ferramenta utilizada neste passo:
    Plastic Cards
    $2.99
    • Remove the laptop's bottom cover using an opening tool or plastic card.
    • Do not use a metal tool during this process. Doing so would risk damaging both the cover and the electrical components.
    • Be gentle during removal. Do not force the cover off, or it may break.
  4. Acer Nitro 5 AN515-55-53AG Internal Fan Replacement: passo 4, imagem 1 %32 Acer Nitro 5 AN515-55-53AG Internal Fan Replacement: passo 4, imagem 2 %32
    • Detach the fan's wire connector from the motherboard.
  5. Acer Nitro 5 AN515-55-53AG Internal Fan Replacement: passo 5, imagem 1 %32
    • Peel up the two strips of black tape holding the fan.
    • Do not peel the tape all the way off. Leave the tape attached to the heatsink.
  6. Acer Nitro 5 AN515-55-53AG Internal Fan Replacement: passo 6, imagem 1 %32 Acer Nitro 5 AN515-55-53AG Internal Fan Replacement: passo 6, imagem 2 %32 Acer Nitro 5 AN515-55-53AG Internal Fan Replacement: passo 6, imagem 3 %32
    • Remove the two screws holding the fan in place using a Phillips #0 screwdriver.
    • Remove the old fan by pulling it directly up.
  7. Acer Nitro 5 AN515-55-53AG Internal Fan Replacement: passo 7, imagem 1 %32 Acer Nitro 5 AN515-55-53AG Internal Fan Replacement: passo 7, imagem 2 %32
    • While the fan is out, clean the space with a cloth or a can of compressed air. Clean the fan vents and plate of any dust.
Conclusão
Um comentário
на an515-55-534c система охлаждения так же разбирается ? или это он и есть ?
Антон Хабаров - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 35
Últimos 30 dias: 83
Duração total: 6,076
