Ir para o conteúdo principal
Acer Nitro 5 AN515-55 SSD Replacement
O que você precisa
  1. Acer Nitro 5 AN515-55 SSD Replacement, SSD: passo 1, imagem 1 %32
    • Shut down your laptop.
    • Make sure your laptop is completely turned off to prevent damaging other parts.
  2. Acer Nitro 5 AN515-55 SSD Replacement: passo 2, imagem 1 %32 Acer Nitro 5 AN515-55 SSD Replacement: passo 2, imagem 2 %32 Acer Nitro 5 AN515-55 SSD Replacement: passo 2, imagem 3 %32
    • Flip the laptop on its back.
    • Remove the eleven 8 mm screws securing the back cover using the Phillips #1 screwdriver.
  3. Acer Nitro 5 AN515-55 SSD Replacement: passo 3, imagem 1 %32 Acer Nitro 5 AN515-55 SSD Replacement: passo 3, imagem 2 %32
    • Loosen the back cover using a plastic opening tool.
  4. Acer Nitro 5 AN515-55 SSD Replacement: passo 4, imagem 1 %32 Acer Nitro 5 AN515-55 SSD Replacement: passo 4, imagem 2 %32
    • Pull the back cover off and put it in a safe place.
    • A little bit of force is needed to pry open the clips at the corners of the laptop.
  5. Acer Nitro 5 AN515-55 SSD Replacement: passo 5, imagem 1 %32 Acer Nitro 5 AN515-55 SSD Replacement: passo 5, imagem 2 %32 Acer Nitro 5 AN515-55 SSD Replacement: passo 5, imagem 3 %32
    • Remove the 2.6 mm screw that is holding down the SSD with a Phillips #0 screwdriver.
    • Make sure to ground yourself before working on the motherboard to prevent damage.
  6. Acer Nitro 5 AN515-55 SSD Replacement: passo 6, imagem 1 %32 Acer Nitro 5 AN515-55 SSD Replacement: passo 6, imagem 2 %32 Acer Nitro 5 AN515-55 SSD Replacement: passo 6, imagem 3 %32
    • Gently pull out the damaged SSD.
  7. Acer Nitro 5 AN515-55 SSD Replacement: passo 7, imagem 1 %32 Acer Nitro 5 AN515-55 SSD Replacement: passo 7, imagem 2 %32
    • Slide in the new SSD.
    • Screw it in place.
  8. Acer Nitro 5 AN515-55 SSD Replacement: passo 8, imagem 1 %32 Acer Nitro 5 AN515-55 SSD Replacement: passo 8, imagem 2 %32
    • Put the back cover on and gently snap the clips back in.
    • Screw the back cover in place.
Conclusão
Follow the guide that comes with your new SSD to make sure your laptop recognizes your new SSD.
6 outras pessoas executaram este guia.
Solomon Mekuria
Membro desde: 03/22/21
292 Reputação
Autoria de 1 guia
Equipe
Um comentário
This model is supposed to have 3 slots 2 for SSD and 1 for HDD, can you please point them out? Just add an extra SDD?
mayumidb - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 7
Últimos 7 dias: 46
Últimos 30 dias: 247
Ao todo: 9,666
