Introdução
Use this guide to replace the Speakers in the Acer Nitro 5 Acer Nitro 5 AN515-53-55G9. This laptop has two speakers that come installed into the device.
O que você precisa
Flip the laptop upside down so that the bottom is facing up.
Identify the RAM tray on the bottom of the laptop.
Removing the back shell of the computer and it will look like this.
The battery for the device is located at the bottom middle of the laptop at this orientation.
One part you missed was to tell everyone that the HDD would still be attached to the back shell. I removed the shell and promptly ripped out my HDD cable. Now having to order a new cable…
Once the battery is removed your device should look similar to this.
Locate the plug for the speakers located at the red circle.
Unplug the cable from the motherboard as shown.
Carefully unroute the cables starting from the main plug.
6 outras pessoas executaram este guia.
