Ir para o conteúdo principal
Acer Nitro 5 AN515-53-55G9 SSD Replacement
O que você precisa
  1. Acer Nitro 5 AN515-53-55G9 SSD Replacement, Battery: passo 1, imagem 1 %32 Acer Nitro 5 AN515-53-55G9 SSD Replacement, Battery: passo 1, imagem 2 %32 Acer Nitro 5 AN515-53-55G9 SSD Replacement, Battery: passo 1, imagem 3 %32
    • Make sure laptop is off and unplugged before beginning replacement.
    • Flip the laptop upside down so that the bottom is facing up.
    • Identify the RAM tray on the bottom of the laptop.
  2. Acer Nitro 5 AN515-53-55G9 SSD Replacement: passo 2, imagem 1 %32 Acer Nitro 5 AN515-53-55G9 SSD Replacement: passo 2, imagem 2 %32 Acer Nitro 5 AN515-53-55G9 SSD Replacement: passo 2, imagem 3 %32
    • Use the Phillips #0 screwdriver to remove the 9mm screw in the bottom left corner of the RAM tray covering.
    • Remove the RAM tray cover by prying up with a spudger.
  3. Acer Nitro 5 AN515-53-55G9 SSD Replacement: passo 3, imagem 1 %32 Acer Nitro 5 AN515-53-55G9 SSD Replacement: passo 3, imagem 2 %32 Acer Nitro 5 AN515-53-55G9 SSD Replacement: passo 3, imagem 3 %32
    • Identify the Hard Drive tray to the left side of the laptop.
    • Remove screw with a #0 Philips screwdriver.
    • Lift up the Slot covering using a spunger.
  4. Acer Nitro 5 AN515-53-55G9 SSD Replacement: passo 4, imagem 1 %32
    • Use the Phillips #0 screwdriver to remove the 9mm screws holding the back cover in place.
    • Remove the screws from the hard drive and remove it from the device.
  5. Acer Nitro 5 AN515-53-55G9 SSD Replacement: passo 5, imagem 1 %32 Acer Nitro 5 AN515-53-55G9 SSD Replacement: passo 5, imagem 2 %32 Acer Nitro 5 AN515-53-55G9 SSD Replacement: passo 5, imagem 3 %32
    • Be sure you removed the hard drive. when you open the back shell and hard drive is built in this may cause damage to cable and other components.
    • Carefully remove the back shell from the device working your way around all the edges.
    • Do not forcefully try to separate the shell as you may cause harm to the shell.
  6. Acer Nitro 5 AN515-53-55G9 SSD Replacement: passo 6, imagem 1 %32 Acer Nitro 5 AN515-53-55G9 SSD Replacement: passo 6, imagem 2 %32
    • Removing the back shell of the computer and it will look like this.
    • The battery for the device is located at the bottom middle of the laptop at this orientation.
  7. Acer Nitro 5 AN515-53-55G9 SSD Replacement: passo 7, imagem 1 %32 Acer Nitro 5 AN515-53-55G9 SSD Replacement: passo 7, imagem 2 %32 Acer Nitro 5 AN515-53-55G9 SSD Replacement: passo 7, imagem 3 %32
    • Locate the connector of the battery to the motherboard.
    • Using your fingers, slide out the connector.
  8. Acer Nitro 5 AN515-53-55G9 SSD Replacement: passo 8, imagem 1 %32
    • Remove battery from device.
  9. Acer Nitro 5 AN515-53-55G9 SSD Replacement, SSD: passo 9, imagem 1 %32 Acer Nitro 5 AN515-53-55G9 SSD Replacement, SSD: passo 9, imagem 2 %32
    • Locate the SSD in the top right corner of the laptop.
  10. Acer Nitro 5 AN515-53-55G9 SSD Replacement: passo 10, imagem 1 %32 Acer Nitro 5 AN515-53-55G9 SSD Replacement: passo 10, imagem 2 %32 Acer Nitro 5 AN515-53-55G9 SSD Replacement: passo 10, imagem 3 %32
    • Use the Phillips #0 screwdriver to remove the 3mm screw holding the SSD card in place.
    • The SSD will pop up at an angle when the screw is removed.
  11. Acer Nitro 5 AN515-53-55G9 SSD Replacement: passo 11, imagem 1 %32
    • Slide the SSD out of its slot.
Conclusão
9 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 37
Últimos 30 dias: 171
Duração total: 22,441
