Ir para o conteúdo principal
Acer Nitro 5 AN515-53-52FA Fan Replacement
O que você precisa
  1. Acer Nitro 5 AN515-53-52FA Fan Replacement, Fan: passo 1, imagem 1 %32
    • Before starting the replacement, make sure the laptop is turned off and unplugged.
    • Flip the laptop upside down so that the bottom is facing up
  2. Acer Nitro 5 AN515-53-52FA Fan Replacement: passo 2, imagem 1 %32 Acer Nitro 5 AN515-53-52FA Fan Replacement: passo 2, imagem 2 %32
    • Use the Phillips #0 screwdriver to unscrew the sixteen 9 mm screws holding the back cover in place.
  3. Acer Nitro 5 AN515-53-52FA Fan Replacement: passo 3, imagem 1 %32 Acer Nitro 5 AN515-53-52FA Fan Replacement: passo 3, imagem 2 %32
    • Use a plastic opening pick to work your way around the edges to remove the bottom case carefully.
    • Do not try to put too much force on the shell off as you may damage it.
    • Removing the backshell of the laptop will reveal the inside of it.
    • The fan of the laptop is located on the top left of the laptop.
  4. Acer Nitro 5 AN515-53-52FA Fan Replacement: passo 4, imagem 1 %32 Acer Nitro 5 AN515-53-52FA Fan Replacement: passo 4, imagem 2 %32
    • Use the Phillips #0 screwdriver to remove the four 9 mm screws securing the fans.
  5. Acer Nitro 5 AN515-53-52FA Fan Replacement: passo 5, imagem 1 %32 Acer Nitro 5 AN515-53-52FA Fan Replacement: passo 5, imagem 2 %32 Acer Nitro 5 AN515-53-52FA Fan Replacement: passo 5, imagem 3 %32
    • Unplug the connectors before taking the fan out.
  6. Acer Nitro 5 AN515-53-52FA Fan Replacement: passo 6, imagem 1 %32 Acer Nitro 5 AN515-53-52FA Fan Replacement: passo 6, imagem 2 %32
    • Gently remove the fans from the adhesive strip.
Conclusão
6 outras pessoas executaram este guia.
Alfredo Prieto
Membro desde: 09/01/22
908 Reputação
Autoria de 5 guias
Equipe
Gateway, Team 1-3, Pee Fall 2022 Membro de Gateway, Team 1-3, Pee Fall 2022
GCC-PEE-F22S1G3
Membros da 4
Autoria de 7 guias
2 comentários
This helped me out. The instructions were completely easy to follow. Thank you so much!
Adam - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 13
Últimos 30 dias: 66
Duração total: 1,451
