Ir para o conteúdo principal
Acer Nitro 5 AN515-53-52FA Battery Replacement
O que você precisa
  1. Acer Nitro 5 AN515-53-52FA Battery Replacement, Battery: passo 1, imagem 1 %32
    • Before starting the replacement, make sure the laptop is turned off and unplugged.
    • Flip the laptop upside down so that the bottom is facing up.
  2. Acer Nitro 5 AN515-53-52FA Battery Replacement: passo 2, imagem 1 %32 Acer Nitro 5 AN515-53-52FA Battery Replacement: passo 2, imagem 2 %32
    • Use the Phillips #0 screwdriver to unscrew the sixteen 9 mm screws holding the back cover in place.
  3. Acer Nitro 5 AN515-53-52FA Battery Replacement: passo 3, imagem 1 %32 Acer Nitro 5 AN515-53-52FA Battery Replacement: passo 3, imagem 2 %32
    • Use the opening pick to work your way around the edges to remove the bottom case carefully.
    • Do not try to put too much force on the shell off as you may damage it.
  4. Acer Nitro 5 AN515-53-52FA Battery Replacement: passo 4, imagem 1 %32
    • Use the Phillips #0 screwdriver to unscrew the four 9 mm screws holding the battery in place.
  5. Acer Nitro 5 AN515-53-52FA Battery Replacement: passo 5, imagem 1 %32 Acer Nitro 5 AN515-53-52FA Battery Replacement: passo 5, imagem 2 %32
    • Disconnect the battery's motherboard connector with your fingers.
  6. Acer Nitro 5 AN515-53-52FA Battery Replacement: passo 6, imagem 1 %32 Acer Nitro 5 AN515-53-52FA Battery Replacement: passo 6, imagem 2 %32
    • Lift the battery up and out of the laptop.
Conclusão
Uma outra pessoa concluiu este guia.
Alfredo Prieto
Membro desde: 09/01/22
827 Reputação
Autoria de 5 guias
Equipe
Gateway, Team 1-3, Pee Fall 2022 Membro de Gateway, Team 1-3, Pee Fall 2022
GCC-PEE-F22S1G3
Membros da 4
Autoria de 5 guias
2 comentários
Do I have to use other material to put the bottom case back on or is it easy to do by hand?
SomeDude372 - Responder
Can I use a Jimmy instead of the opening picks?
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 7
Últimos 7 dias: 26
Últimos 30 dias: 81
Duração total: 951
