Ir para o conteúdo principal
Acer Iconia W3-810 Speaker Replacement
O que você precisa
  1. Acer Iconia W3-810 Speaker Replacement, Back Panel: passo 1, imagem 1 %32
    • Place the tablet face down on a flat surface with the charger facing toward you.
  2. Acer Iconia W3-810 Speaker Replacement: passo 2, imagem 1 %32
    • Use a plastic opening tool to pry the back panel off of the device.
    • Be careful to not use the plastic opening tool near the charging dock or any media ports.
  3. Acer Iconia W3-810 Speaker Replacement, Speaker: passo 3, imagem 1 %32
    • Lift the retaining flaps fastening the screen ribbon cord to the screen circuit board using a plastic opening tool.
  4. Acer Iconia W3-810 Speaker Replacement: passo 4, imagem 1 %32
    • Pull the ribbon cord out of its slot.
  5. Acer Iconia W3-810 Speaker Replacement: passo 5, imagem 1 %32
    • Lift the retaining flap fastening the ribbon cord.
  6. Acer Iconia W3-810 Speaker Replacement: passo 6, imagem 1 %32
    • Remove the ribbon cord from its slot.
  7. Acer Iconia W3-810 Speaker Replacement: passo 7, imagem 1 %32
    • Unscrew the Phillips head HH0 3mm screws holding down the right speaker.
  8. Acer Iconia W3-810 Speaker Replacement: passo 8, imagem 1 %32
    • Unscrew the HHO 3mm screws holding the left speaker.
  9. Acer Iconia W3-810 Speaker Replacement: passo 9, imagem 1 %32
    • Lift the speakers from the front panel.
  10. Acer Iconia W3-810 Speaker Replacement: passo 10, imagem 1 %32
    • Pull the speakers underneath the headphone cord.
  11. Acer Iconia W3-810 Speaker Replacement: passo 11, imagem 1 %32
    • Use a plastic opening tool to remove the speaker cord from its slot.
  12. Acer Iconia W3-810 Speaker Replacement: passo 12, imagem 1 %32
    • Remove the speakers from the device.
Conclusão
Griffin Hocker
Membro desde: 09/15/16
394 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 18-4, Blackwell Fall 2016 Membro de USF Tampa, Team 18-4, Blackwell Fall 2016
USFT-BLACKWELL-F16S18G4
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 4
Últimos 30 dias: 8
Duração total: 436
