Ir para o conteúdo principal
Acer Iconia W3-810 Front Facing Camera
O que você precisa
  1. Acer Iconia W3-810 Front Facing Camera, Back Panel: passo 1, imagem 1 %32
    • Place the tablet face down on a flat surface with the charger facing toward you.
  2. Acer Iconia W3-810 Front Facing Camera: passo 2, imagem 1 %32
    • Use a plastic opening tool to pry the back panel off of the device.
    • Be careful to not use the plastic opening tool near the charging dock or any media ports.
  3. Acer Iconia W3-810 Front Facing Camera, Front Facing Camera: passo 3, imagem 1 %32
    • Loosen the retaining flap connected to the front-facing camera by lifting it with a plastic opening tool.
  4. Acer Iconia W3-810 Front Facing Camera: passo 4, imagem 1 %32
    • Remove the ribbon cord from its slot by pushing it out with a plastic opening tool.
  5. Acer Iconia W3-810 Front Facing Camera: passo 5, imagem 1 %32
    • Simple replacement for another camera.
Conclusão
Griffin Hocker
Membro desde: 09/15/16
394 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 18-4, Blackwell Fall 2016 Membro de USF Tampa, Team 18-4, Blackwell Fall 2016
USFT-BLACKWELL-F16S18G4
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 454
