Ir para o conteúdo principal
Acer Iconia Tablet A100 Screen Cover Glass Replacement
O que você precisa
  1. Acer Iconia Tablet A100 Screen Cover Glass Replacement, Screen Cover Glass: passo 1, imagem 1 %32
    • Begin with the screen facing in the upward position.
  2. Acer Iconia Tablet A100 Screen Cover Glass Replacement: passo 2, imagem 1 %32
    • Remove the four side pieces of the tablet.
    • Start with either side and work your way around the tablet.
  3. Acer Iconia Tablet A100 Screen Cover Glass Replacement: passo 3, imagem 1 %32 Acer Iconia Tablet A100 Screen Cover Glass Replacement: passo 3, imagem 2 %32 Acer Iconia Tablet A100 Screen Cover Glass Replacement: passo 3, imagem 3 %32
    • Separate the screen from the device with a plastic opening tool (four sides in total).
    • Start with a plastic opening tool along the top perimeter of the tablet, the thin line, and remove the screen.
  4. Acer Iconia Tablet A100 Screen Cover Glass Replacement: passo 4, imagem 1 %32
    • Grab the new screen, and place on top of the tablet.
    • Position it to where everything is aligned correctly.
  5. Acer Iconia Tablet A100 Screen Cover Glass Replacement: passo 5, imagem 1 %32
    • Put the four side pieces back in its original place.
Conclusão
Omar Acosta
Membro desde: 03/03/15
526 Reputação
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 1,193
