Introdução
If it says "Too many pattern attempts..." or not working Android system, or you want to erase all data.
__________Video tutorial:__________
Vídeo de Apresentação
From the reset hole we can make reset without erasing data.
Now you are in the Boot Mode menu. With Vol(+), (-) go to [SD Update Image Mode] and select it with Power On key.
After restart you will have empty (free of data) device and access to it.
11 outras pessoas executaram este guia.
2 comentários
I have a problem when it came to SD image update mode I get the log acer restarts does not pass the second part you have any idea?
tengo un problema cuando entró a SD image update mode me sale el log de acer se reinicia no pasa a la segunda parte tienes alguna idea ?
