Introdução
The USB-A/Micro-USB Port enhances the connectivity of the tablet to other portable devices. Follow this guide to replace the USB-A/Micro-USB Port.
O que você precisa
Use a plastic opening tool to carefully separate the back cover, starting at the volume buttons.
Continue separating the back cover along the short side closest to the camera and around the device.
Ferramenta utilizada nesse passo:Tweezers$3.99
Use the angled tweezers to disconnect the white motherboard-battery connector in the middle of the side opposite the docking port.
Ferramenta utilizada nesse passo:Halberd Spudger$2.99
Use the Halberd Spudger to carefully pop up and take out the ports.
