Ir para o conteúdo principal
Acer Iconia Tab A500 Power Button/Motherboard Replacement
O que você precisa
  1. Acer Iconia Tab A500 Power Button/Motherboard Replacement, Back Case: passo 1, imagem 1 %32
    • To start, gently separate one corner of the case using the black spudger.
  2. Acer Iconia Tab A500 Power Button/Motherboard Replacement: passo 2, imagem 1 %32
    • Once you have successfully pried the spudger in between the front case and back case, continue do so around the entire tablet until the back case is completely disconnected.
  3. Acer Iconia Tab A500 Power Button/Motherboard Replacement, Speakers: passo 3, imagem 1 %32
    • Locate the 4 screws and cable that hold in the two speakers.
    • Use the Phillips #1 screwdriver to remove these 2mm black screws.
    • Remove the 2mm silver screws.
    • Not all 4 screws are going to be the same kind. This will not affect the speaker replacement.
  4. Acer Iconia Tab A500 Power Button/Motherboard Replacement: passo 4, imagem 1 %32 Acer Iconia Tab A500 Power Button/Motherboard Replacement: passo 4, imagem 2 %32
    • Carefully remove the connector cable by pushing on the rim of black plastic insert.
  5. Acer Iconia Tab A500 Power Button/Motherboard Replacement: passo 5, imagem 1 %32
    • Unfortunately, the top speaker is a wedged under the motherboard.
    • To get this speaker out, use the spudger and gently pry it out.
  6. Acer Iconia Tab A500 Power Button/Motherboard Replacement, Battery: passo 6, imagem 1 %32
    • Remove the 5mm screws that are securing the battery to the rest of the tablet.
    • Use the Phillips #00 Screwdriver to remove the 5mm screws.
  7. Acer Iconia Tab A500 Power Button/Motherboard Replacement: passo 7, imagem 1 %32
    • Use the sharper end of the spudger to disconnect the battery from the mother board.
    • The battery connector will slide off.
  8. Acer Iconia Tab A500 Power Button/Motherboard Replacement, Power Button: passo 8, imagem 1 %32
    • Using the Phillips #1 screwdriver, remove the screws near the edges of the tablet.
    • They may be different sizes, the silver are 5mm and the black are 2mm.
  9. Acer Iconia Tab A500 Power Button/Motherboard Replacement: passo 9, imagem 1 %32
    • Lift up on the black flaps to release the flat cables.
    • Pull this Connector off.
  10. Acer Iconia Tab A500 Power Button/Motherboard Replacement: passo 10, imagem 1 %32
    • Use the spudger to detach the indicated cables.
    • Remove the last motherboard screw under the rightmost cable. It is a silver 5mm.
  11. Acer Iconia Tab A500 Power Button/Motherboard Replacement: passo 11, imagem 1 %32
    • Disconnect the two gold connectors by pulling straight up on them with your fingers.
    • Like before, lift up on the black flap to detach the cable.
  12. Acer Iconia Tab A500 Power Button/Motherboard Replacement: passo 12, imagem 1 %32
    • Having disconnected all those pesky cables, the motherboard lifts cleanly out.
Conclusão
From here, you can solder on a new switch or put in the new motherboard. To reassemble your device, follow these instructions in reverse order.
20 outras pessoas executaram este guia.
Kyle Libby
Membro desde: 04/07/14
1.006 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 7-23, Regan Spring 2014 Membro de Cal Poly, Team 7-23, Regan Spring 2014
CPSU-REGAN-S14S7G23
Membros da 4
Autoria de 19 guias
2 comentários
where can I get the switch?
Dan - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 23
Duração total: 14,615
