Introdução
The Acer Iconia Tab uses a Li-Po 3260 mAh battery that is screwed into the device.
O que você precisa
With the plastic opening tool pry open the grey plastic siding on both sides of the tablet.
Uma outra pessoa concluiu este guia.
2 comentários
Instructions should point out that when removing the device from the case that prying tool must got between the gasket and plastic case, NOT between the screen and the gasket. I hope my cracked screen will still work!
What are the specifications to purchase a new battery for my icona Acer tablet 200 ?
