Introdução
If your device no longer plays sound, this guide shows you how to fix the problem.
O que você precisa
Insert the plastic opening tool into the seam between the back case and the display.
Work the plastic opening tool around the seam until the rear case separates from the display.
Using a spudger, work the tool under the battery connector located above the battery on the left side, and lift it free.
