Ir para o conteúdo principal
Acer Iconia One 8 Motherboard Replacement
O que você precisa
  1. Acer Iconia One 8 Motherboard Replacement, Screen: passo 1, imagem 1 %32 Acer Iconia One 8 Motherboard Replacement, Screen: passo 1, imagem 2 %32
    • Begin by opening the back panel.
    • Wedge a plastic opening tool in between the front and back shell and gently separate.
  2. Acer Iconia One 8 Motherboard Replacement: passo 2, imagem 1 %32 Acer Iconia One 8 Motherboard Replacement: passo 2, imagem 2 %32 Acer Iconia One 8 Motherboard Replacement: passo 2, imagem 3 %32
    • Peel back all pieces of tape indicated in picture.
    • There are three pieces of tape total (2 Black and 1 Silver).
  3. Acer Iconia One 8 Motherboard Replacement: passo 3, imagem 1 %32 Acer Iconia One 8 Motherboard Replacement: passo 3, imagem 2 %32 Acer Iconia One 8 Motherboard Replacement: passo 3, imagem 3 %32
    • Disconnect all cables from the device.
    • There should be 5 total.
  4. Acer Iconia One 8 Motherboard Replacement: passo 4, imagem 1 %32 Acer Iconia One 8 Motherboard Replacement: passo 4, imagem 2 %32 Acer Iconia One 8 Motherboard Replacement: passo 4, imagem 3 %32
    • Remove the nine 3mm screws using the Phillips #000 screwdriver.
  5. Acer Iconia One 8 Motherboard Replacement: passo 5, imagem 1 %32
    • Remove and separate the back plating (top) from the glass screen (bottom).
  6. Acer Iconia One 8 Motherboard Replacement, Motherboard: passo 6, imagem 1 %32 Acer Iconia One 8 Motherboard Replacement, Motherboard: passo 6, imagem 2 %32
    • Disconnect the metal tabs connecting the battery to the motherboard frame.
  7. Acer Iconia One 8 Motherboard Replacement: passo 7, imagem 1 %32 Acer Iconia One 8 Motherboard Replacement: passo 7, imagem 2 %32
    • Disconnect the cable for the back camera.
  8. Acer Iconia One 8 Motherboard Replacement: passo 8, imagem 1 %32
    • Flip the metal plating to reveal the front camera.
  9. Acer Iconia One 8 Motherboard Replacement: passo 9, imagem 1 %32 Acer Iconia One 8 Motherboard Replacement: passo 9, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use tweezers to carefully remove the front camera from the adhesive on the motherboard.
  10. Acer Iconia One 8 Motherboard Replacement: passo 10, imagem 1 %32 Acer Iconia One 8 Motherboard Replacement: passo 10, imagem 2 %32 Acer Iconia One 8 Motherboard Replacement: passo 10, imagem 3 %32
    • Flip the device back over.
    • Remove the motherboard from the metallic frame by feeding the back camera and front camera cable through the port.
    • Remove the front camera from the device.
Conclusão
Dustin Newland
Membro desde: 11/06/19
343 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team S1-G2, Stella Fall 2019 Membro de IUPUI, Team S1-G2, Stella Fall 2019
IUPUI-STELLA-F19S1G2
Membros da 3
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 255
