Ir para o conteúdo principal
Acer Iconia One 8 Battery Replacement
O que você precisa
  1. Acer Iconia One 8 Battery Replacement, Battery: passo 1, imagem 1 %32 Acer Iconia One 8 Battery Replacement, Battery: passo 1, imagem 2 %32
    • To remove the back panel, insert an opening tool into the small crack between the screen and back panel. Gently pry open the tablet.
  2. Acer Iconia One 8 Battery Replacement: passo 2, imagem 1 %32
    • Remove the black piece of tape that is holding the red, yellow, and white wires in place.
  3. Acer Iconia One 8 Battery Replacement: passo 3, imagem 1 %32
    • Once the tape has been removed, gently pinch the wires and remove them from the socket. They should come out easily.
  4. Acer Iconia One 8 Battery Replacement: passo 4, imagem 1 %32
    • Carefully work a plastic spudger underneath the battery and pry it free.
    • Use an iOpener or carefully apply heat with a heat gun to soften the adhesive under the battery.
    • Be careful not to bend or puncture the battery.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 12
Duração total: 2,887
