Ir para o conteúdo principal
Acer Iconia One 7 Speaker Replacement
O que você precisa
  1. Acer Iconia One 7 Speaker Replacement, Speaker: passo 1, imagem 1 %32
    • Begin at any side of the tablet.
    • With a plastic opening tool, begin taking apart the back cover from the tablet by working along the edges.
    • Prying the lid open can be difficult; use caution in order to safely remove.
    • Turn off device before this step.
  2. Acer Iconia One 7 Speaker Replacement: passo 2, imagem 1 %32
    • Using a plastic opening tool, separate the back cover from the main device.
    • Open each side continuously to ensure all sides have been separated.
  3. Acer Iconia One 7 Speaker Replacement: passo 3, imagem 1 %32
    • Turn the tablet over to locate the speaker.
    • Besides the parts that are mentioned in the instruction, try not to agitate other fragile components inside the device.
    • The speaker is on the bottom of the inside.
  4. Acer Iconia One 7 Speaker Replacement: passo 4, imagem 1 %32 Acer Iconia One 7 Speaker Replacement: passo 4, imagem 2 %32
    • Peel back tape.
    • Using tweezers, detach connection from motherboard.
  5. Acer Iconia One 7 Speaker Replacement: passo 5, imagem 1 %32 Acer Iconia One 7 Speaker Replacement: passo 5, imagem 2 %32 Acer Iconia One 7 Speaker Replacement: passo 5, imagem 3 %32
    • Unscrew screws with a JIS screwdriver with a #00 screw bit.
    • Dislodge the speaker unit.
    • Take care not to displace any other bits in the device.
Conclusão
Michael
Membro desde: 09/03/15
519 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 8-5, Eyestone Fall 2015 Membro de USF Tampa, Team 8-5, Eyestone Fall 2015
USFT-EYESTONE-F15S8G5
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 9
Duração total: 405
