Ir para o conteúdo principal
Acer Iconia One 7 Rear-Facing Camera Replacement
O que você precisa
  1. Acer Iconia One 7 Rear-Facing Camera Replacement, Rear-Facing Camera: passo 1, imagem 1 %32
    • Begin at any side of the tablet.
    • With a plastic opening tool, begin taking apart the back cover from the tablet by working along the edges.
    • Prying the lid open can be difficult, use caution in order to safely remove.
    • Turn off device before this step.
  2. Acer Iconia One 7 Rear-Facing Camera Replacement: passo 2, imagem 1 %32
    • Using a plastic opening tool, separate the back cover from the main device.
    • Open each side continuously to ensure all sides have been separated.
  3. Acer Iconia One 7 Rear-Facing Camera Replacement: passo 3, imagem 1 %32
    • Turn the tablet over to locate the camera on the top left.
    • Besides the parts that are mentioned in the instruction, try not to agitate other fragile components inside the device.
  4. Acer Iconia One 7 Rear-Facing Camera Replacement: passo 4, imagem 1 %32 Acer Iconia One 7 Rear-Facing Camera Replacement: passo 4, imagem 2 %32
    • Peel black tape.
    • Detach clip from motherboard.
  5. Acer Iconia One 7 Rear-Facing Camera Replacement: passo 5, imagem 1 %32 Acer Iconia One 7 Rear-Facing Camera Replacement: passo 5, imagem 2 %32
    • Take out film object using tweezers.
    • Using tweezers take out camera.
Conclusão
Michael
Membro desde: 09/03/15
519 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 8-5, Eyestone Fall 2015 Membro de USF Tampa, Team 8-5, Eyestone Fall 2015
USFT-EYESTONE-F15S8G5
Membros da 3
Autoria de 5 guias
Um comentário
How to get new camera if the original camera is damaged
Prakash Hasabnis - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 10
Duração total: 424
