Ir para o conteúdo principal
Acer Iconia One 7 Motherboard Replacement
O que você precisa
    • Reminder: Turn off device before you start opening your tablet.
  1. Acer Iconia One 7 Motherboard Replacement: passo 2, imagem 1 %32
    • Begin at any side of the tablet.
    • With a plastic opening tool, begin taking apart the back cover from the tablet by working along the edges.
    • Use caution when prying the lid open to avoid damaging your tablet.
  2. Acer Iconia One 7 Motherboard Replacement: passo 3, imagem 1 %32
    • Using a plastic opening tool, separate the back cover from the main device
    • Open each side continuously to ensure all sides have been separated,
  3. Acer Iconia One 7 Motherboard Replacement: passo 4, imagem 1 %32
    • Turn tablet over.
    • Lay the tablet on a flat surface with the screen facing down. Locate the copper cover along the outside of the tablet.
  4. Acer Iconia One 7 Motherboard Replacement: passo 5, imagem 1 %32
    • Carefully peel back the copper foil to reveal the motherboard.
  5. Acer Iconia One 7 Motherboard Replacement: passo 6, imagem 1 %32
    • Peel tape back to expose connections.
  6. Acer Iconia One 7 Motherboard Replacement: passo 7, imagem 1 %32 Acer Iconia One 7 Motherboard Replacement: passo 7, imagem 2 %32
    • There are several sets of wires connected to the motherboard as shown in the images. Carefully disconnect each set of wires.
  7. Acer Iconia One 7 Motherboard Replacement: passo 8, imagem 1 %32 Acer Iconia One 7 Motherboard Replacement: passo 8, imagem 2 %32
    • Use a JIS screw bit #00 to remove screws around the motherboard using the provided image to locate each screw.
  8. Acer Iconia One 7 Motherboard Replacement: passo 9, imagem 1 %32
    • Gently pull out motherboard.
Conclusão
4 outras pessoas executaram este guia.
Michael
Membro desde: 09/03/15
519 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 8-5, Eyestone Fall 2015 Membro de USF Tampa, Team 8-5, Eyestone Fall 2015
USFT-EYESTONE-F15S8G5
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 13
Duração total: 2,568
