Ir para o conteúdo principal
Acer Iconia One 7 Front Facing Camera Replacement
O que você precisa
  1. Acer Iconia One 7 Front Facing Camera Replacement, Front-Facing Camera: passo 1, imagem 1 %32
    • Begin at any side of the tablet.
    • With a plastic opening tool, begin taking apart the back cover from the tablet by working along the edges.
    • Prying the lid open can be difficult, use caution in order to safely remove.
    • Turn off device before this step.
  2. Acer Iconia One 7 Front Facing Camera Replacement: passo 2, imagem 1 %32
    • Using a plastic opening tool, separate the back cover from the main device.
    • Open each side continuously to ensure all sides have been separated.
  3. Acer Iconia One 7 Front Facing Camera Replacement: passo 3, imagem 1 %32
    • Turn tablet over.
    • Locate front-facing camera.
  4. Acer Iconia One 7 Front Facing Camera Replacement: passo 4, imagem 1 %32
    • Pull black tape with front-facing camera.
Conclusão
Uma outra pessoa concluiu este guia.
Michael
Membro desde: 09/03/15
519 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 8-5, Eyestone Fall 2015 Membro de USF Tampa, Team 8-5, Eyestone Fall 2015
USFT-EYESTONE-F15S8G5
Membros da 3
Autoria de 5 guias
Um comentário
Be carefful when pulling the stick tape. It is very strong and can break the flex cable of the camera and other flex cables...
Egas - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 1,176
