Introdução
The battery is essential to the Acer Iconia One 7 as it powers the entire device. One should be careful when replacing a battery because it may be dangerous if the battery is punctured. Taking apart the battery itself without proper safety precautions could prove to be hazardous to one’s health. Power down the device before beginning this repair.
O que você precisa
Begin prying the front from the back on any side of the tablet. Gently work your way around the tablet with the prying tool.
Ferramenta utilizada nesse passo:Plastic Cards$2.99
Using a plastic card or opening pick, separate the battery from the rest of the device.
6 outras pessoas executaram este guia.
4 comentários
is there a replacement batt that can fit here or other brand that can fit? like from samsing tab? acer battery sucks
My acer iconia one 7 battery model is 308292 wnd there is no tutorial regarding replacing battery. Thank
Where I can order the new battery part?
