Ir para o conteúdo principal
Acer Iconia One 10 B3-A30 Repair Power Switch Replacement
O que você precisa
  1. Acer Iconia One 10 B3-A30 Repair Power Switch Replacement, Battery: passo 1, imagem 1 %32 Acer Iconia One 10 B3-A30 Repair Power Switch Replacement, Battery: passo 1, imagem 2 %32
    • Make sure the device is powered off.
    • Open media port cover at the top of the tablet.
    • Use the Phillips #00 screwdriver to remove the 1 mm screw.
  2. Acer Iconia One 10 B3-A30 Repair Power Switch Replacement: passo 2, imagem 1 %32 Acer Iconia One 10 B3-A30 Repair Power Switch Replacement: passo 2, imagem 2 %32 Acer Iconia One 10 B3-A30 Repair Power Switch Replacement: passo 2, imagem 3 %32
    • Using the metal spudger, carefully pry open the back cover.
  3. Acer Iconia One 10 B3-A30 Repair Power Switch Replacement: passo 3, imagem 1 %32
    • Remove small section of grey tape.
  4. Acer Iconia One 10 B3-A30 Repair Power Switch Replacement: passo 4, imagem 1 %32 Acer Iconia One 10 B3-A30 Repair Power Switch Replacement: passo 4, imagem 2 %32
    • Unplug the connection cord from the motherboard.
  5. Acer Iconia One 10 B3-A30 Repair Power Switch Replacement: passo 5, imagem 1 %32 Acer Iconia One 10 B3-A30 Repair Power Switch Replacement: passo 5, imagem 2 %32 Acer Iconia One 10 B3-A30 Repair Power Switch Replacement: passo 5, imagem 3 %32
    • Try to remove the battery by pulling on the blue tabs.
    • If unsuccessful, use the black plastic spudger to gently break the glue bonds underneath and pull up to remove the battery.
    • Be very cautious not to puncture or bend the battery.
  6. Acer Iconia One 10 B3-A30 Repair Power Switch Replacement, Motherboard: passo 6, imagem 1 %32 Acer Iconia One 10 B3-A30 Repair Power Switch Replacement, Motherboard: passo 6, imagem 2 %32 Acer Iconia One 10 B3-A30 Repair Power Switch Replacement, Motherboard: passo 6, imagem 3 %32
    • Remove all of the tape surrounding the motherboard.
  7. Acer Iconia One 10 B3-A30 Repair Power Switch Replacement: passo 7, imagem 1 %32 Acer Iconia One 10 B3-A30 Repair Power Switch Replacement: passo 7, imagem 2 %32
    • Starting with the 2 large connections use the plastic opening tool to gently pry on the connections and pop them out.
    • Now, disconnect the two smaller black and red cords from the motherboard.
  8. Acer Iconia One 10 B3-A30 Repair Power Switch Replacement: passo 8, imagem 1 %32
    • Scrape away the small square sticker to reveal one small screw. Use the Phillips #00 screwdriver to remove the screw.
    • Using the same screwdriver remove the other three screws on the motherboard.
  9. Acer Iconia One 10 B3-A30 Repair Power Switch Replacement: passo 9, imagem 1 %32 Acer Iconia One 10 B3-A30 Repair Power Switch Replacement: passo 9, imagem 2 %32
    • Using the small plastic tool, carefully pry the motherboard out of the device.
  10. Acer Iconia One 10 B3-A30 Repair Power Switch Replacement, Power Switch: passo 10, imagem 1 %32 Acer Iconia One 10 B3-A30 Repair Power Switch Replacement, Power Switch: passo 10, imagem 2 %32
    • Depress power switch using finger, and simultaneously pry in same direction with a plastic opening tool.
Conclusão
Uma outra pessoa concluiu este guia.
Austin Pickart
Membro desde: 09/28/17
688 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S1-G5, Nance Fall 2017 Membro de USF Tampa, Team S1-G5, Nance Fall 2017
USFT-NANCE-F17S1G5
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 16
Duração total: 1,987
