Ir para o conteúdo principal
Acer Iconia B1-720 Microphone/Speaker Replacement
O que você precisa
  1. Acer Iconia B1-720 Microphone/Speaker Replacement, Rear Case: passo 1, imagem 1 %32 Acer Iconia B1-720 Microphone/Speaker Replacement, Rear Case: passo 1, imagem 2 %32 Acer Iconia B1-720 Microphone/Speaker Replacement, Rear Case: passo 1, imagem 3 %32
    • Insert a plastic opening tool into a gap near the charging port at the top of the device. Slide the tool in either direction along the device.
  2. Acer Iconia B1-720 Microphone/Speaker Replacement: passo 2, imagem 1 %32 Acer Iconia B1-720 Microphone/Speaker Replacement: passo 2, imagem 2 %32 Acer Iconia B1-720 Microphone/Speaker Replacement: passo 2, imagem 3 %32
    • Slide the tool along until you have completely separated the rear cover.
    • If needed, place the first tool in the gap created to hold this gap open and use a second tool to pry the remaining portion of the rear cover off.
  3. Acer Iconia B1-720 Microphone/Speaker Replacement: passo 3, imagem 1 %32 Acer Iconia B1-720 Microphone/Speaker Replacement: passo 3, imagem 2 %32
    • Once all the sides have been separated, you should be able to simply lift the cover off of the device.
  4. Acer Iconia B1-720 Microphone/Speaker Replacement, Microphone/Speaker: passo 4, imagem 1 %32 Acer Iconia B1-720 Microphone/Speaker Replacement, Microphone/Speaker: passo 4, imagem 2 %32 Acer Iconia B1-720 Microphone/Speaker Replacement, Microphone/Speaker: passo 4, imagem 3 %32
    • Pry the speaker away from the device using the plastic opening tool. This may require a little force due to the adhesive that is on the device.(Battery is not shown in this picture for image
    • Tug gently on microphone to remove from slot.
  5. Acer Iconia B1-720 Microphone/Speaker Replacement: passo 5, imagem 1 %32 Acer Iconia B1-720 Microphone/Speaker Replacement: passo 5, imagem 2 %32
    • Unwind the wire from the running channel.
    • To remove microphone, follow same steps.
  6. Acer Iconia B1-720 Microphone/Speaker Replacement: passo 6, imagem 1 %32 Acer Iconia B1-720 Microphone/Speaker Replacement: passo 6, imagem 2 %32
    • Unplug connector from motherboard.
    • Follow same procedure to remove microphone.
    • Unplug the microphone in a similar fashion as with the speaker.
Conclusão
Phillip Keavey
Membro desde: 03/17/15
319 Reputação
Autoria de 2 guias
Equipe
Michigan Tech, Team 1-1, Lauer Spring 2015 Membro de Michigan Tech, Team 1-1, Lauer Spring 2015
MTU-LAUER-S15S1G1
Membros da 2
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 6
Duração total: 690
