Ir para o conteúdo principal
Acer Iconia B1-720 Front Facing Camera Replacement
O que você precisa
  1. Acer Iconia B1-720 Front Facing Camera Replacement, Rear Case: passo 1, imagem 1 %32 Acer Iconia B1-720 Front Facing Camera Replacement, Rear Case: passo 1, imagem 2 %32 Acer Iconia B1-720 Front Facing Camera Replacement, Rear Case: passo 1, imagem 3 %32
    • Insert a plastic opening tool into a gap near the charging port at the top of the device. Slide the tool in either direction along the device.
  2. Acer Iconia B1-720 Front Facing Camera Replacement: passo 2, imagem 1 %32 Acer Iconia B1-720 Front Facing Camera Replacement: passo 2, imagem 2 %32 Acer Iconia B1-720 Front Facing Camera Replacement: passo 2, imagem 3 %32
    • Slide the tool along until you have completely separated the rear cover.
    • If needed, place the first tool in the gap created to hold this gap open and use a second tool to pry the remaining portion of the rear cover off.
  3. Acer Iconia B1-720 Front Facing Camera Replacement: passo 3, imagem 1 %32 Acer Iconia B1-720 Front Facing Camera Replacement: passo 3, imagem 2 %32
    • Once all the sides have been separated, you should be able to simply lift the cover off of the device.
  4. Acer Iconia B1-720 Front Facing Camera Replacement, Microphone/Speaker: passo 4, imagem 1 %32 Acer Iconia B1-720 Front Facing Camera Replacement, Microphone/Speaker: passo 4, imagem 2 %32 Acer Iconia B1-720 Front Facing Camera Replacement, Microphone/Speaker: passo 4, imagem 3 %32
    • Pry the speaker away from the device using the plastic opening tool. This may require a little force due to the adhesive that is on the device.(Battery is not shown in this picture for image
    • Tug gently on microphone to remove from slot.
  5. Acer Iconia B1-720 Front Facing Camera Replacement: passo 5, imagem 1 %32 Acer Iconia B1-720 Front Facing Camera Replacement: passo 5, imagem 2 %32
    • Unwind the wire from the running channel.
    • To remove microphone, follow same steps.
  6. Acer Iconia B1-720 Front Facing Camera Replacement: passo 6, imagem 1 %32 Acer Iconia B1-720 Front Facing Camera Replacement: passo 6, imagem 2 %32
    • Unplug connector from motherboard.
    • Follow same procedure to remove microphone.
    • Unplug the microphone in a similar fashion as with the speaker.
  7. Acer Iconia B1-720 Front Facing Camera Replacement, Motherboard: passo 7, imagem 1 %32 Acer Iconia B1-720 Front Facing Camera Replacement, Motherboard: passo 7, imagem 2 %32 Acer Iconia B1-720 Front Facing Camera Replacement, Motherboard: passo 7, imagem 3 %32
    • Remove the yellow tape covering both ribbons in the two photos shown.
  8. Acer Iconia B1-720 Front Facing Camera Replacement: passo 8, imagem 1 %32 Acer Iconia B1-720 Front Facing Camera Replacement: passo 8, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use tweezers to lift the small black locking tab off of the orange ribbon
    • Remove the orange ribbon from the lock using tweezers
  9. Acer Iconia B1-720 Front Facing Camera Replacement: passo 9, imagem 1 %32 Acer Iconia B1-720 Front Facing Camera Replacement: passo 9, imagem 2 %32 Acer Iconia B1-720 Front Facing Camera Replacement: passo 9, imagem 3 %32
    • Use tweezers to remove rubber black wrap surrounding lock.
    • Use the tweezers to pull plastic tabs on each side of the black ribbon
  10. Acer Iconia B1-720 Front Facing Camera Replacement: passo 10, imagem 1 %32 Acer Iconia B1-720 Front Facing Camera Replacement: passo 10, imagem 2 %32
    • Use tweezers to gently remove black ribbon from locking mechanism.
  11. Acer Iconia B1-720 Front Facing Camera Replacement: passo 11, imagem 1 %32 Acer Iconia B1-720 Front Facing Camera Replacement: passo 11, imagem 2 %32 Acer Iconia B1-720 Front Facing Camera Replacement: passo 11, imagem 3 %32
    • Remove the 5 screws shown in the photograph
    • Lift the motherboard from the front panel of the device.
  12. Acer Iconia B1-720 Front Facing Camera Replacement, Front Facing Camera: passo 12, imagem 1 %32
    • Flip the motherboard over so that you see the camera, micro usb port, and headphone jack.
    • The object marked in red is the camera.
  13. Acer Iconia B1-720 Front Facing Camera Replacement: passo 13, imagem 1 %32 Acer Iconia B1-720 Front Facing Camera Replacement: passo 13, imagem 2 %32
    • Grab and gently lift the camera up from the motherboard until it becomes disconnected.
Conclusão
Uma outra pessoa concluiu este guia.
Kervis Boston
Membro desde: 03/18/15
479 Reputação
Autoria de 3 guias
Equipe
Michigan Tech, Team 1-1, Lauer Spring 2015 Membro de Michigan Tech, Team 1-1, Lauer Spring 2015
MTU-LAUER-S15S1G1
Membros da 2
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 10
Duração total: 404
