Ir para o conteúdo principal
Acer Iconia B1-720 Battery Replacement
O que você precisa
  1. Acer Iconia B1-720 Battery Replacement, Rear Case: passo 1, imagem 1 %32 Acer Iconia B1-720 Battery Replacement, Rear Case: passo 1, imagem 2 %32 Acer Iconia B1-720 Battery Replacement, Rear Case: passo 1, imagem 3 %32
    • Insert a plastic opening tool into a gap near the charging port at the top of the device. Slide the tool in either direction along the device.
  2. Acer Iconia B1-720 Battery Replacement: passo 2, imagem 1 %32 Acer Iconia B1-720 Battery Replacement: passo 2, imagem 2 %32 Acer Iconia B1-720 Battery Replacement: passo 2, imagem 3 %32
    • Slide the tool along until you have completely separated the rear cover.
    • If needed, place the first tool in the gap created to hold this gap open and use a second tool to pry the remaining portion of the rear cover off.
  3. Acer Iconia B1-720 Battery Replacement: passo 3, imagem 1 %32 Acer Iconia B1-720 Battery Replacement: passo 3, imagem 2 %32
    • Once all the sides have been separated, you should be able to simply lift the cover off of the device.
  4. Acer Iconia B1-720 Battery Replacement, Battery: passo 4, imagem 1 %32 Acer Iconia B1-720 Battery Replacement, Battery: passo 4, imagem 2 %32
    • Peel back the plastic tape covering the battery connector.
  5. Acer Iconia B1-720 Battery Replacement: passo 5, imagem 1 %32
    • Use the plastic opening tool to lift the battery off of the back panel. The adhesive used is strong so apply force during removal.
  6. Acer Iconia B1-720 Battery Replacement: passo 6, imagem 1 %32 Acer Iconia B1-720 Battery Replacement: passo 6, imagem 2 %32 Acer Iconia B1-720 Battery Replacement: passo 6, imagem 3 %32
    • Lift the battery off of the panel gently. This will disconnect the battery connector from the motherboard.
Conclusão
5 outras pessoas executaram este guia.
Kervis Boston
Membro desde: 03/18/15
479 Reputação
Autoria de 3 guias
Equipe
Michigan Tech, Team 1-1, Lauer Spring 2015 Membro de Michigan Tech, Team 1-1, Lauer Spring 2015
MTU-LAUER-S15S1G1
Membros da 2
Autoria de 5 guias
2 comentários
Why the battery has a 4 pin connector? I tried to buy another generic battery but it got only 2 cables, don't know how to replace :(
Tadeu - Responder
I just wanted to throw a red flag out there…I broke my connector off the motherboard trying to reinstall the four-pin connection…can anyone advise?
John Merritt - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 7
Duração total: 2,883
