Ir para o conteúdo principal
Acer Iconia B1-710 Tablet Camera Replacement
O que você precisa
  1. Acer Iconia B1-710 Tablet Camera Replacement, Battery: passo 1, imagem 1 %32 Acer Iconia B1-710 Tablet Camera Replacement, Battery: passo 1, imagem 2 %32 Acer Iconia B1-710 Tablet Camera Replacement, Battery: passo 1, imagem 3 %32
    • Open the back cover by prying the casing off with an opening tool.
    • Be careful to not pull pieces apart aggressively. There is a wire that could break.
  2. Acer Iconia B1-710 Tablet Camera Replacement: passo 2, imagem 1 %32 Acer Iconia B1-710 Tablet Camera Replacement: passo 2, imagem 2 %32 Acer Iconia B1-710 Tablet Camera Replacement: passo 2, imagem 3 %32
    • Unplug the battery from the motherboard.
  3. Acer Iconia B1-710 Tablet Camera Replacement: passo 3, imagem 1 %32
    • Remove the battery.
    • The battery is lightly glued in, so there may be some difficulty getting it out.
  4. Acer Iconia B1-710 Tablet Camera Replacement, Camera: passo 4, imagem 1 %32 Acer Iconia B1-710 Tablet Camera Replacement, Camera: passo 4, imagem 2 %32
    • Remove the five 3mm Phillips #000 screws. The location of the screws are shown in the above picture, circled in red.
    • Keep the removed screws in a safe place so they can be used later.
  5. Acer Iconia B1-710 Tablet Camera Replacement: passo 5, imagem 1 %32 Acer Iconia B1-710 Tablet Camera Replacement: passo 5, imagem 2 %32
    • Unplug the LCD by lifting the LCD plug from the white board. The location of the LCD plug is shown in the above picture, circled in red.
    • If you are having difficulty removing the LCD plug, use a spudger to gently lift it.
  6. Acer Iconia B1-710 Tablet Camera Replacement: passo 6, imagem 1 %32 Acer Iconia B1-710 Tablet Camera Replacement: passo 6, imagem 2 %32
    • Next, unplug the orange strip from the motherboard by gently lifting it. The location of the orange strip is shown in the above picture, circled in red.
    • The orange strip is delicate; be careful when unplugging it and make sure it doesn't tear.
  7. Acer Iconia B1-710 Tablet Camera Replacement: passo 7, imagem 1 %32 Acer Iconia B1-710 Tablet Camera Replacement: passo 7, imagem 2 %32 Acer Iconia B1-710 Tablet Camera Replacement: passo 7, imagem 3 %32
    • Unplug the white wire, shown above, circled in red.
    • Unplug the black wire, shown above, circled in orange.
  8. Acer Iconia B1-710 Tablet Camera Replacement: passo 8, imagem 1 %32
    • Gently, remove the motherboard by carefully lifting it.
  9. Acer Iconia B1-710 Tablet Camera Replacement: passo 9, imagem 1 %32 Acer Iconia B1-710 Tablet Camera Replacement: passo 9, imagem 2 %32 Acer Iconia B1-710 Tablet Camera Replacement: passo 9, imagem 3 %32
    • Remove the camera from the motherboard with the spudger.
    • Be careful not to damage the camera plug; it is very delicate.
Conclusão
To reassemble your device, follow the above instructions in reverse order.
Uma outra pessoa concluiu este guia.
Ryan Weber
Membro desde: 03/26/17
358 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team S3-G5, Baechle Spring 2017 Membro de IUPUI, Team S3-G5, Baechle Spring 2017
IUPUI-BAECHLE-S17S3G5
Membros da 4
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 10
Duração total: 354
