Ir para o conteúdo principal
Acer Iconia B1-710 Screen Replacement
O que você precisa
  1. Acer Iconia B1-710 Screen Replacement, Battery: passo 1, imagem 1 %32 Acer Iconia B1-710 Screen Replacement, Battery: passo 1, imagem 2 %32 Acer Iconia B1-710 Screen Replacement, Battery: passo 1, imagem 3 %32
    • Open the back cover by prying the casing off with an opening tool.
    • Be careful to not pull pieces apart aggressively. There is a wire that could break.
  2. Acer Iconia B1-710 Screen Replacement: passo 2, imagem 1 %32 Acer Iconia B1-710 Screen Replacement: passo 2, imagem 2 %32 Acer Iconia B1-710 Screen Replacement: passo 2, imagem 3 %32
    • Unplug the battery from the motherboard.
  3. Acer Iconia B1-710 Screen Replacement: passo 3, imagem 1 %32
    • Remove the battery.
    • The battery is lightly glued in, so there may be some difficulty getting it out.
  4. Acer Iconia B1-710 Screen Replacement, Screen: passo 4, imagem 1 %32 Acer Iconia B1-710 Screen Replacement, Screen: passo 4, imagem 2 %32
    • Unscrew all five 3 mm #000 Phillips screws.
  5. Acer Iconia B1-710 Screen Replacement: passo 5, imagem 1 %32 Acer Iconia B1-710 Screen Replacement: passo 5, imagem 2 %32
    • Unplug the LCD ribbon.
  6. Acer Iconia B1-710 Screen Replacement: passo 6, imagem 1 %32 Acer Iconia B1-710 Screen Replacement: passo 6, imagem 2 %32
    • Unplug the orange ribbon.
  7. Acer Iconia B1-710 Screen Replacement: passo 7, imagem 1 %32 Acer Iconia B1-710 Screen Replacement: passo 7, imagem 2 %32 Acer Iconia B1-710 Screen Replacement: passo 7, imagem 3 %32
    • Unplug the white wire from the motherboard.
    • Unplug the black wire from the motherboard.
  8. Acer Iconia B1-710 Screen Replacement: passo 8, imagem 1 %32
    • Pull the motherboard off of the tablet.
  9. Acer Iconia B1-710 Screen Replacement: passo 9, imagem 1 %32
    • Use a blow dryer to melt the glue holding the LCD display in place.
    • Patience is key. It will take a few minutes to melt the glue.
  10. Acer Iconia B1-710 Screen Replacement: passo 10, imagem 1 %32 Acer Iconia B1-710 Screen Replacement: passo 10, imagem 2 %32 Acer Iconia B1-710 Screen Replacement: passo 10, imagem 3 %32
    • Peel the LCD display.
    • This piece is fragile and needs to be peeled with care.
    • Parts may be hot.
  11. Acer Iconia B1-710 Screen Replacement: passo 11, imagem 1 %32
    • Use a blow dryer to melt the glue from the thin metal frame.
    • This piece is metal and will become hot during this process.
  12. Acer Iconia B1-710 Screen Replacement: passo 12, imagem 1 %32 Acer Iconia B1-710 Screen Replacement: passo 12, imagem 2 %32
    • Peel off the thin metal frame.
    • Be careful not to bend the frame as it is very thin.
  13. Acer Iconia B1-710 Screen Replacement: passo 13, imagem 1 %32
    • Use a blow dryer to melt the glue between the metal frame and the screen.
    • The frame will get hot.
  14. Acer Iconia B1-710 Screen Replacement: passo 14, imagem 1 %32 Acer Iconia B1-710 Screen Replacement: passo 14, imagem 2 %32
    • Peel the frame from the screen.
    • Be careful when peeling the screen or it may sustain further damage.
Conclusão
Uma outra pessoa concluiu este guia.
Ryan Weber
Membro desde: 03/26/17
358 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team S3-G5, Baechle Spring 2017 Membro de IUPUI, Team S3-G5, Baechle Spring 2017
IUPUI-BAECHLE-S17S3G5
4 Membros
Autoria de 3 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 7
Ao todo: 986
