Ir para o conteúdo principal
Acer Iconia A110 Front Facing Camera Replacement
O que você precisa
  1. Acer Iconia A110 Front Facing Camera Replacement, Battery: passo 1, imagem 1 %32 Acer Iconia A110 Front Facing Camera Replacement, Battery: passo 1, imagem 2 %32
    • Before taking apart your tablet, make sure the device is powered off.
    • Pry open the right side of case with the plastic opening tool. If necessary, keep a tool lodged into the side to keep the case from closing.
    • During this process, the volume button and/or power button may fall out.
  2. Acer Iconia A110 Front Facing Camera Replacement: passo 2, imagem 1 %32 Acer Iconia A110 Front Facing Camera Replacement: passo 2, imagem 2 %32 Acer Iconia A110 Front Facing Camera Replacement: passo 2, imagem 3 %32
    • Pry open the left side of the case with a plastic opening tool. The backside of the tablet should now separate completely from the front.
  3. Acer Iconia A110 Front Facing Camera Replacement: passo 3, imagem 1 %32 Acer Iconia A110 Front Facing Camera Replacement: passo 3, imagem 2 %32 Acer Iconia A110 Front Facing Camera Replacement: passo 3, imagem 3 %32
    • Using the plastic opening tool and spudger, carefully pry up the battery from the case.
    • You should hear the adhesive ripping as you do this.
    • Once the battery is no longer adhered to the case, detach the dongle that connects the battery to the motherboard.
  4. Acer Iconia A110 Front Facing Camera Replacement, Speaker: passo 4, imagem 1 %32 Acer Iconia A110 Front Facing Camera Replacement, Speaker: passo 4, imagem 2 %32
    • With the Phillips #00 screwdriver, remove the following screws securing the motherboard to the back panel:
    • Two 2.0 mm screws (with the bigger head)
    • Four 2.5 mm screws (with the smaller head)
  5. Acer Iconia A110 Front Facing Camera Replacement: passo 5, imagem 1 %32 Acer Iconia A110 Front Facing Camera Replacement: passo 5, imagem 2 %32
    • On the top right side of the motherboard, is the vibration motor. With tweezers, carefully pull the vibration motor out from underneath the motherboard.
    • The vibration motor is still connected to the motherboard by a small wire connection, so be careful not to rip the wire out.
    • With your fingers, carefully disconnect the cable securing the vibration motor to the motherboard. Set aside.
  6. Acer Iconia A110 Front Facing Camera Replacement: passo 6, imagem 1 %32 Acer Iconia A110 Front Facing Camera Replacement: passo 6, imagem 2 %32
    • The speaker located on the top of the motherboard should easily slide out. Take note that there is still a wire connected, so do so carefully.
    • With your fingers, slowly pull out the wire connecting the speaker to the motherboard.
  7. Acer Iconia A110 Front Facing Camera Replacement, Motherboard: passo 7, imagem 1 %32 Acer Iconia A110 Front Facing Camera Replacement, Motherboard: passo 7, imagem 2 %32 Acer Iconia A110 Front Facing Camera Replacement, Motherboard: passo 7, imagem 3 %32
    • The next step is to pull out the ribbon cables connected to the motherboard.
    • Each ribbon cable has a sticker covering it; peel it off with tweezers.
    • Use tweezers to pull out the ribbon cable.
    • Make sure to pull the ribbon cable horizontally, not vertically to avoid tearing the ribbon
  8. Acer Iconia A110 Front Facing Camera Replacement: passo 8, imagem 1 %32 Acer Iconia A110 Front Facing Camera Replacement: passo 8, imagem 2 %32 Acer Iconia A110 Front Facing Camera Replacement: passo 8, imagem 3 %32
    • After all ribbon cables are disconnected,move them out of the way, and the motherboard should fall out easily.
  9. Acer Iconia A110 Front Facing Camera Replacement, Front Facing Camera: passo 9, imagem 1 %32 Acer Iconia A110 Front Facing Camera Replacement, Front Facing Camera: passo 9, imagem 2 %32 Acer Iconia A110 Front Facing Camera Replacement, Front Facing Camera: passo 9, imagem 3 %32
    • Carefully gripping the top of the camera connection cord, slowly pull down to remove the sticky tape from the tablet.
Conclusão
3 outras pessoas executaram este guia.
Andrea
Membro desde: 04/14/14
757 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 3-42, Maness Spring 2014 Membro de Cal Poly, Team 3-42, Maness Spring 2014
CPSU-MANESS-S14S3G42
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 5
Duração total: 948
