Ir para o conteúdo principal
Acer Iconia A110 Battery Replacement
O que você precisa
  1. Acer Iconia A110 Battery Replacement, Battery: passo 1, imagem 1 %32 Acer Iconia A110 Battery Replacement, Battery: passo 1, imagem 2 %32
    • Before taking apart your tablet, make sure the device is powered off.
    • Pry open the right side of case with the plastic opening tool. If necessary, keep a tool lodged into the side to keep the case from closing.
    • During this process, the volume button and/or power button may fall out.
  2. Acer Iconia A110 Battery Replacement: passo 2, imagem 1 %32 Acer Iconia A110 Battery Replacement: passo 2, imagem 2 %32 Acer Iconia A110 Battery Replacement: passo 2, imagem 3 %32
    • Pry open the left side of the case with a plastic opening tool. The backside of the tablet should now separate completely from the front.
  3. Acer Iconia A110 Battery Replacement: passo 3, imagem 1 %32 Acer Iconia A110 Battery Replacement: passo 3, imagem 2 %32 Acer Iconia A110 Battery Replacement: passo 3, imagem 3 %32
    • Using the plastic opening tool and spudger, carefully pry up the battery from the case.
    • You should hear the adhesive ripping as you do this.
    • Once the battery is no longer adhered to the case, detach the dongle that connects the battery to the motherboard.
Conclusão
3 outras pessoas executaram este guia.
Andrea
Membro desde: 04/14/14
757 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 3-42, Maness Spring 2014 Membro de Cal Poly, Team 3-42, Maness Spring 2014
CPSU-MANESS-S14S3G42
Membros da 4
Autoria de 5 guias
Um comentário
Where can you purchase the battery for acer iconia tab a110?
redd4167 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 7
Últimos 30 dias: 11
Duração total: 11,241
