Ir para o conteúdo principal
Acer Iconia A100 Speakers Replacement
O que você precisa
  1. Acer Iconia A100 Speakers Replacement, Battery: passo 1, imagem 1 %32
    • Start at any side of the tablet.
    • Begin to take apart the tablet with a plastic opening tool along the sides of the tablet.
    • Work your way around the tablet.
    • There are four side pieces in total.
  2. Acer Iconia A100 Speakers Replacement: passo 2, imagem 1 %32
    • Remove the five 4 mm screws from the edges of the tablet with a Phillips #00 screwdriver.
  3. Acer Iconia A100 Speakers Replacement: passo 3, imagem 1 %32
    • Carefully separate the back piece from the device using a plastic opening tool.
    • Remember to open along the entire perimeter of the tablet.
  4. Acer Iconia A100 Speakers Replacement: passo 4, imagem 1 %32
    • Turn the tablet over so that the battery is facing upwards.
    • Remove the four 4mm screws located around the battery.
  5. Acer Iconia A100 Speakers Replacement: passo 5, imagem 1 %32 Acer Iconia A100 Speakers Replacement: passo 5, imagem 2 %32
    • Use the tip of a plastic spudger or opening tool to gently push the connector head out of its socket.
    • Use your fingers or the flat edge of a plastic opening tool to lift the battery up and off of the device.
    • Be sure to not have any water around the device while removing the battery.
    • Be sure to be cautious while removing the battery and remove carefully; avoid ripping the wires attached to the battery.
  6. Acer Iconia A100 Speakers Replacement, Speakers: passo 6, imagem 1 %32 Acer Iconia A100 Speakers Replacement, Speakers: passo 6, imagem 2 %32 Acer Iconia A100 Speakers Replacement, Speakers: passo 6, imagem 3 %32
    • Locate the speakers module, which consists of 2 square black speakers connected by wires.
    • Locate the white and blue Home Key FFC ribbon cable between the speakers.
    • Use the tip of a spudger or opening tool to lift up and flip the small hinge on the connector. Then gently pull the FFC ribbon cable out its connector socket.
    • While a metal spudger tool is shown here and may be used, it is best to use a plastic spudger or opening tool when possible. It is easier to damage cables when using metal tools, so be extra cautious when using a metal spudger like the one shown here!
  7. Acer Iconia A100 Speakers Replacement: passo 7, imagem 1 %32 Acer Iconia A100 Speakers Replacement: passo 7, imagem 2 %32
    • Locate the speaker cable. Use your fingers to pinch each side of the black head of the speaker cable, and gently pull it out of its socket.
    • The metal spudger shown in the photo is used only to identify the speaker cable, not remove it.
    • If you're unable to get a good grip on the black connector head itself, gently pull from the wires near the connector head's base.
    • Be sure to pull on the wires near the base and evenly on the full width of the wires so no individual wire is over-strained, which may cause damage!
  8. Acer Iconia A100 Speakers Replacement: passo 8, imagem 1 %32 Acer Iconia A100 Speakers Replacement: passo 8, imagem 2 %32
    • Unscrew the 4mm Phillips screws securing the speakers module to the device using a Phillips #00 screwdriver.
    • There are two 4mm screws in total (one screw securing each speaker).
  9. Acer Iconia A100 Speakers Replacement: passo 9, imagem 1 %32 Acer Iconia A100 Speakers Replacement: passo 9, imagem 2 %32
    • Now both speakers should be free. Use the edge of a spudger tool to lift each speaker off the device, or use your hands to simultaneously lift each square black speaker off of the device.
    • If intact, the two speakers should be connected by wires, forming a one-piece speakers module.
Conclusão
Uma outra pessoa concluiu este guia.
Omar Acosta
Membro desde: 03/03/15
526 Reputação
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 358
