Ir para o conteúdo principal
Acer Iconia A1-830 Rear Facing Camera Replacement
O que você precisa
  1. Acer Iconia A1-830 Rear Facing Camera Replacement, Disassembling Acer Iconia A1-830 Back Panel: passo 1, imagem 1 %32 Acer Iconia A1-830 Rear Facing Camera Replacement, Disassembling Acer Iconia A1-830 Back Panel: passo 1, imagem 2 %32
    • Prepare your working space. The ideal work space has a flat, level surface that is clean and well lit.
    • Shut down your Acer Iconia A1-830.
    • Remove any cables or exterior covers from your tablet.
    • Place it on your work space, with the screen facing up.
  2. Acer Iconia A1-830 Rear Facing Camera Replacement: passo 2, imagem 1 %32 Acer Iconia A1-830 Rear Facing Camera Replacement: passo 2, imagem 2 %32
    • Wedge the plastic opening tool into the tiny gap between the white plastic front bezel and the aluminum rear panel.
    • Do not try to pry apart the top edge on the front side near the front-facing camera.
  3. Acer Iconia A1-830 Rear Facing Camera Replacement, Battery: passo 3, imagem 1 %32 Acer Iconia A1-830 Rear Facing Camera Replacement, Battery: passo 3, imagem 2 %32
    • Remove the small clear plastic cover on top of the battery cable with the nylon or metal spudger.
  4. Acer Iconia A1-830 Rear Facing Camera Replacement: passo 4, imagem 1 %32
    • Remove the battery cable by lifting it up with the pointy end of the black nylon spudger.
  5. Acer Iconia A1-830 Rear Facing Camera Replacement: passo 5, imagem 1 %32 Acer Iconia A1-830 Rear Facing Camera Replacement: passo 5, imagem 2 %32
    • Un-stick the battery from the metal plate using the black nylon spudger.
    • Be careful not to puncture the battery while removing it.
  6. Acer Iconia A1-830 Rear Facing Camera Replacement, Rear Facing Camera: passo 6, imagem 1 %32
    • Remove the piece of black tape covering the rear facing camera ribbon cable connector.
  7. Acer Iconia A1-830 Rear Facing Camera Replacement: passo 7, imagem 1 %32 Acer Iconia A1-830 Rear Facing Camera Replacement: passo 7, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Lift up the small white lever on the the ribbon cable connector with the metal tweezers to remove the ribbon cable.
    • Lift out the rear facing camera from the plastic frame with the metal tweezers.
Conclusão
Brendan Coveney
Membro desde: 10/18/15
593 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 4-6, Catania Fall 2015 Membro de UMass Dartmouth, Team 4-6, Catania Fall 2015
UMASSD-CATANIA-F15S4G6
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 428
