Ir para o conteúdo principal
Acer Iconia A1-830 Battery Replacement
O que você precisa
  1. Acer Iconia A1-830 Battery Replacement, Disassembling Acer Iconia A1-830 Back Panel: passo 1, imagem 1 %32 Acer Iconia A1-830 Battery Replacement, Disassembling Acer Iconia A1-830 Back Panel: passo 1, imagem 2 %32
    • Prepare your working space. The ideal work space has a flat, level surface that is clean and well lit.
    • Shut down your Acer Iconia A1-830.
    • Remove any cables or exterior covers from your tablet.
    • Place it on your work space, with the screen facing up.
  2. Acer Iconia A1-830 Battery Replacement: passo 2, imagem 1 %32 Acer Iconia A1-830 Battery Replacement: passo 2, imagem 2 %32
    • Wedge the plastic opening tool into the tiny gap between the white plastic front bezel and the aluminum rear panel.
    • Do not try to pry apart the top edge on the front side near the front-facing camera.
  3. Acer Iconia A1-830 Battery Replacement, Battery: passo 3, imagem 1 %32 Acer Iconia A1-830 Battery Replacement, Battery: passo 3, imagem 2 %32
    • Remove the small clear plastic cover on top of the battery cable with the nylon or metal spudger.
  4. Acer Iconia A1-830 Battery Replacement: passo 4, imagem 1 %32
    • Remove the battery cable by lifting it up with the pointy end of the black nylon spudger.
  5. Acer Iconia A1-830 Battery Replacement: passo 5, imagem 1 %32 Acer Iconia A1-830 Battery Replacement: passo 5, imagem 2 %32
    • Un-stick the battery from the metal plate using the black nylon spudger.
    • Be careful not to puncture the battery while removing it.
Conclusão
5 outras pessoas executaram este guia.
Matt Champagne
Membro desde: 10/20/15
458 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 4-6, Catania Fall 2015 Membro de UMass Dartmouth, Team 4-6, Catania Fall 2015
UMASSD-CATANIA-F15S4G6
Membros da 3
Autoria de 5 guias
2 comentários
Is it okay if the battery bends a slight bit when prying it off?
Doof - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 16
Duração total: 9,086
