Introdução
Replace the motherboard in a Acer Iconia A1-810.
O que você precisa
Remove the back cover by lifting with a plastic opening tool, below the camera button slot.
Use a Phillips #000 screwdriver to remove the screws around the perimeter of the motherboard.
7 outras pessoas executaram este guia.
8 comentários
Can you replace the mini USB charger port without replacing entire motherboard and losing data?
