Ir para o conteúdo principal
Acer Iconia A1-810 Motherboard Replacement
O que você precisa
  1. Acer Iconia A1-810 Motherboard Replacement, Battery: passo 1, imagem 1 %32
    • Remove the back cover by lifting with a plastic opening tool, below the camera button slot.
  2. Acer Iconia A1-810 Motherboard Replacement: passo 2, imagem 1 %32
    • Remove the black tape connecting the battery to the motherboard.
  3. Acer Iconia A1-810 Motherboard Replacement: passo 3, imagem 1 %32
    • Pinch the sides of the white resistor to safely remove it without damaging it or yourself.
  4. Acer Iconia A1-810 Motherboard Replacement: passo 4, imagem 1 %32 Acer Iconia A1-810 Motherboard Replacement: passo 4, imagem 2 %32
    • Remove battery from adhesive.
  5. Acer Iconia A1-810 Motherboard Replacement, Motherboard: passo 5, imagem 1 %32
    • Use a Phillips #000 screwdriver to remove the screws around the perimeter of the motherboard.
  6. Acer Iconia A1-810 Motherboard Replacement: passo 6, imagem 1 %32 Acer Iconia A1-810 Motherboard Replacement: passo 6, imagem 2 %32
    • Disconnect the resistor attached to the orange tab by sliding the tail out.
    • Pry open the orange tab near the top left corner.
  7. Acer Iconia A1-810 Motherboard Replacement: passo 7, imagem 1 %32 Acer Iconia A1-810 Motherboard Replacement: passo 7, imagem 2 %32 Acer Iconia A1-810 Motherboard Replacement: passo 7, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Disconnect all cords, wires, and resistors from the motherboard using tweezers.
  8. Acer Iconia A1-810 Motherboard Replacement: passo 8, imagem 1 %32 Acer Iconia A1-810 Motherboard Replacement: passo 8, imagem 2 %32 Acer Iconia A1-810 Motherboard Replacement: passo 8, imagem 3 %32
    • Continue to disconnect all resistors attached from the motherboard, using tweezers.
  9. Acer Iconia A1-810 Motherboard Replacement: passo 9, imagem 1 %32
    • Gently lift motherboard out.
    • The edges may be sharp.
Conclusão
7 outras pessoas executaram este guia.
John
Membro desde: 01/29/15
635 Reputação
Autoria de 3 guias
Equipe
UWT Liner: Group 3 Membro de UWT Liner: Group 3
Community
Membros da 5
Autoria de 3 guias
8 comentários
I need main ic part num A1-810 iconia I need main ic
mehwish - Responder
It was damage because high voltage
mehwish - Responder
Can you replace the mini USB charger port without replacing entire motherboard and losing data?
theblackfox2 - Responder
Hi there i need acer lconia A3 main bord how much it will cost me ?
Muhammad - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 19
Duração total: 5,418
