Ir para o conteúdo principal
Acer Icona W510 Vibrator Motor Disconnection Prerequisite Only
O que você precisa
  1. Acer Icona W510 Vibrator Motor Disconnection Prerequisite Only, Rear Cover: passo 1, imagem 1 %32 Acer Icona W510 Vibrator Motor Disconnection Prerequisite Only, Rear Cover: passo 1, imagem 2 %32 Acer Icona W510 Vibrator Motor Disconnection Prerequisite Only, Rear Cover: passo 1, imagem 3 %32
    • Carefully insert your metal pry tool between the back cover and the frame at an angle as shown.
    • Give the tool a twist to the left to start separating the clips.
    • Work your way to the corner, prying and twisting to pop the clips as you go.
  2. Acer Icona W510 Vibrator Motor Disconnection Prerequisite Only, Right Side: passo 2, imagem 1 %32 Acer Icona W510 Vibrator Motor Disconnection Prerequisite Only, Right Side: passo 2, imagem 2 %32 Acer Icona W510 Vibrator Motor Disconnection Prerequisite Only, Right Side: passo 2, imagem 3 %32
    • Insert an opening pick to make sure the clips don't close down again as you round the corner and start working on the right side of the tablet.
    • Continue as before, prying and twisting to release the catches.
  3. Acer Icona W510 Vibrator Motor Disconnection Prerequisite Only, Top Edge: passo 3, imagem 1 %32 Acer Icona W510 Vibrator Motor Disconnection Prerequisite Only, Top Edge: passo 3, imagem 2 %32
    • Continue along the top edge as before
    • When you get to the corner, be careful not to insert the tool in the space below the power on symbol. There is a delicate clip there that is easy to break if you're prying with the tool. (Yes, I'm speaking from experience. Don't be me.)
  4. Acer Icona W510 Vibrator Motor Disconnection Prerequisite Only, Left Side: passo 4, imagem 1 %32 Acer Icona W510 Vibrator Motor Disconnection Prerequisite Only, Left Side: passo 4, imagem 2 %32
    • Unclip the left side of the tablet.
  5. Acer Icona W510 Vibrator Motor Disconnection Prerequisite Only, Bottom Edge: passo 5, imagem 1 %32 Acer Icona W510 Vibrator Motor Disconnection Prerequisite Only, Bottom Edge: passo 5, imagem 2 %32
    • Back to the bottom side again, this little part by itself is a little finicky to get unclipped, just follow the same procedure as with the first one.
    • And finally the home stretch between the keyboard/power connector and the right hand guide pin, back to where you started.
  6. Acer Icona W510 Vibrator Motor Disconnection Prerequisite Only: passo 6, imagem 1 %32
    • The rear cover is removed.
  7. Acer Icona W510 Vibrator Motor Disconnection Prerequisite Only, Unplug the Tablet Battery: passo 7, imagem 1 %32 Acer Icona W510 Vibrator Motor Disconnection Prerequisite Only, Unplug the Tablet Battery: passo 7, imagem 2 %32
    • Peel back the tape securing the battery connector.
  8. Acer Icona W510 Vibrator Motor Disconnection Prerequisite Only: passo 8, imagem 1 %32 Acer Icona W510 Vibrator Motor Disconnection Prerequisite Only: passo 8, imagem 2 %32
    • Grasp the plug by the tabs on either side and pull it straight out from the connector.
  9. Acer Icona W510 Vibrator Motor Disconnection Prerequisite Only, Charging Port Disconnection: passo 9, imagem 1 %32 Acer Icona W510 Vibrator Motor Disconnection Prerequisite Only, Charging Port Disconnection: passo 9, imagem 2 %32 Acer Icona W510 Vibrator Motor Disconnection Prerequisite Only, Charging Port Disconnection: passo 9, imagem 3 %32
    • Unstick the grounding tape from the charging connector.
  10. Acer Icona W510 Vibrator Motor Disconnection Prerequisite Only: passo 10, imagem 1 %32 Acer Icona W510 Vibrator Motor Disconnection Prerequisite Only: passo 10, imagem 2 %32
    • Using a spudger, flip up the latch securing the charge port flex cable.
  11. Acer Icona W510 Vibrator Motor Disconnection Prerequisite Only: passo 11, imagem 1 %32
    • Grasp the pull tab on the flex cable and use it to pull the cable out of the connector.
  12. Acer Icona W510 Vibrator Motor Disconnection Prerequisite Only: passo 12, imagem 1 %32 Acer Icona W510 Vibrator Motor Disconnection Prerequisite Only: passo 12, imagem 2 %32
    • The flex cable is lightly adhered to the display frame, so use a spudger to separate it.
  13. Acer Icona W510 Vibrator Motor Disconnection Prerequisite Only, Vibrator Motor Disconnection: passo 13, imagem 1 %32 Acer Icona W510 Vibrator Motor Disconnection Prerequisite Only, Vibrator Motor Disconnection: passo 13, imagem 2 %32 Acer Icona W510 Vibrator Motor Disconnection Prerequisite Only, Vibrator Motor Disconnection: passo 13, imagem 3 %32
    • Remove the two 2.1mm Phillips screws.
  14. Acer Icona W510 Vibrator Motor Disconnection Prerequisite Only: passo 14, imagem 1 %32
    • Flip the cable assembly over carefully, as it is still adhered to the frame by a thin strip of flex cable. Be careful not to break that strip.
  15. Acer Icona W510 Vibrator Motor Disconnection Prerequisite Only: passo 15, imagem 1 %32 Acer Icona W510 Vibrator Motor Disconnection Prerequisite Only: passo 15, imagem 2 %32
    • Unplug the vibration motor from the charging port circuit board.
Conclusão
Jerry Wheeler
Membro desde: 03/21/22
71.389 Reputação
Autoria de 71 guias
Equipe
Oregonians Membro de Oregonians
Community
Membros da 8
Autoria de 189 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 82
