Ir para o conteúdo principal
Acer E5-571-54FL Optical Drive Replacement
O que você precisa
  1. Acer E5-571-54FL Optical Drive Replacement, Battery: passo 1, imagem 1 %32
    • Power down the laptop prior to beginning.
    • Turn the laptop over with the battery closest to your body.
  2. Acer E5-571-54FL Optical Drive Replacement: passo 2, imagem 1 %32 Acer E5-571-54FL Optical Drive Replacement: passo 2, imagem 2 %32
    • Insert the pointed end of a spudger into the battery release.
    • Slide the release gently all the way to the left.
    • You should hear a sound after the slide is all the way left. This lets you know the battery has disengaged.
  3. Acer E5-571-54FL Optical Drive Replacement: passo 3, imagem 1 %32 Acer E5-571-54FL Optical Drive Replacement: passo 3, imagem 2 %32
    • Place your hands on each end of the battery.
    • Pull the battery towards your body to remove it.
  4. Acer E5-571-54FL Optical Drive Replacement, Optical Drive: passo 4, imagem 1 %32
    • Remove the single screw that holds the optical drive in place using the Phillips #0 screwdriver.
  5. Acer E5-571-54FL Optical Drive Replacement: passo 5, imagem 1 %32 Acer E5-571-54FL Optical Drive Replacement: passo 5, imagem 2 %32 Acer E5-571-54FL Optical Drive Replacement: passo 5, imagem 3 %32
    • Slide out the old optical drive and remove it from the device.
Conclusão
Jennifer Hancock
Membro desde: 09/19/19
325 Reputação
Autoria de 3 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 7
Ao todo: 486
