Introdução
Is your laptop overheating? Are you hearing strange noises coming from inside the case? It may be time to replace your CPU Cooling fan.
O que você precisa
Power down the laptop prior to beginning.
Turn the laptop over with the battery closest to your body.
Using a #0 Phillips screwdriver, remove a total of eighteen identical 8mm Phillips screws and set them aside.
Locate the CPU cooling fan in the upper left corner of the laptop.
Using a #0 Phillips screwdriver, remove the two 4.5 mm screws that secure the fan to the case.
