Ir para o conteúdo principal
Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement
O que você precisa
  1. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Back Panel: passo 1, imagem 1 %32 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Back Panel: passo 1, imagem 2 %32
    • Power off the laptop before beginning the replacement.
    • Using the Phillips #1 screwdriver, remove eighteen 7 mm screws from the back panel of the device.
  2. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: passo 2, imagem 1 %32 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: passo 2, imagem 2 %32
    • Use a plastic opening tool around the edges of the laptop and remove the back panel from the device.
  3. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Remove the battery cable: passo 3, imagem 1 %32
    • Push on the sides of the connector with a plastic spudger to separate the cable from the motherboard.
  4. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Battery: passo 4, imagem 1 %32 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Battery: passo 4, imagem 2 %32
    • Using the Phillips #1 screwdriver, remove the two black 5.5 mm screws securing the battery.
  5. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: passo 5, imagem 1 %32
    • Remove the battery from the laptop.
  6. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Unplug the WiFi Antenna Connectors: passo 6, imagem 1 %32 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Unplug the WiFi Antenna Connectors: passo 6, imagem 2 %32
    • Firmly pull the end of the black wire attached to the Wi-Fi card upwards and remove it from the device.
    • Repeat with the white wire.
  7. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Deroute the Black WiFi Wire: passo 7, imagem 1 %32 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Deroute the Black WiFi Wire: passo 7, imagem 2 %32
    • Deroute the black wifi wire from its slot in the palm rest.
  8. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Deroute the White WiFi Wire: passo 8, imagem 1 %32 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Deroute the White WiFi Wire: passo 8, imagem 2 %32
    • Deroute the white wifi wire from the slot in the palm rest.
  9. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Disconnect the Display Cable: passo 9, imagem 1 %32 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Disconnect the Display Cable: passo 9, imagem 2 %32 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Disconnect the Display Cable: passo 9, imagem 3 %32
    • Pull the end of the display cable attached to the motherboard straight up to remove.
    • Rotate the cable out away from the motherboard.
  10. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Remove Right Hinge Screws: passo 10, imagem 1 %32
    • Remove the two screws from the right hinge.
  11. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: passo 11, imagem 1 %32 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: passo 11, imagem 2 %32
    • Insert a screwdriver or spudger under the hinge to get it started then rotate it open by hand as far as possible.
  12. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Remove Left Hinge Screws: passo 12, imagem 1 %32
    • Remove the two screws from the left hinge.
  13. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: passo 13, imagem 1 %32 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: passo 13, imagem 2 %32
  14. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Remove the display assembly: passo 14, imagem 1 %32 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Remove the display assembly: passo 14, imagem 2 %32 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Remove the display assembly: passo 14, imagem 3 %32
    • Lift the palm rest assembly from the front then slide it away from the hinges slightly to remove the assembly from the display.
  15. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Touchpad: passo 15, imagem 1 %32 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Touchpad: passo 15, imagem 2 %32
    • Flip up the retaining latch securing the touchpad cable to the motherboard.
  16. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: passo 16, imagem 1 %32
    • Pull the ribbon from the motherboard laterally off the touchpad.
  17. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: passo 17, imagem 1 %32
    • Using the Phillips #1 screwdriver, remove the three 3.2 mm screws holding the touchpad to the laptop.
  18. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: passo 18, imagem 1 %32 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: passo 18, imagem 2 %32 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: passo 18, imagem 3 %32
    • Carefully lift up on the keyboard ribbon cable and the insulating sheet immediately below it so the touchpad can clear them.
    • Lift the touchpad slightly from the top.
    • Pull the touchpad toward the motherboard as you continue to lift it, sliding it out from under the retaining fingers at the bottom.
  19. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: passo 19, imagem 1 %32 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: passo 19, imagem 2 %32 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: passo 19, imagem 3 %32
    • Remove the touchpad.
    • When reinstalling:
    • Make sure the touchpad goes underneath the two retaining fingers when reinstalling it.
    • The touchpad is correctly aligned when the guide pins next to the left and right screws are inserted in the holes.
  20. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Disconnect the Speakers: passo 20, imagem 1 %32 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Disconnect the Speakers: passo 20, imagem 2 %32
    • Pull the black ribbon attached to the speakers out of the motherboard.
  21. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Speakers: passo 21, imagem 1 %32
    • Pry the right speaker up with your hand to remove.
  22. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: passo 22, imagem 1 %32 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: passo 22, imagem 2 %32
    • Thread the speaker under the black ribbon towards the left to allow removal of the left speaker.
  23. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: passo 23, imagem 1 %32
    • Pry up the left speaker to remove it.
    • Remove both speakers.
  24. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Keyboard Cable: passo 24, imagem 1 %32 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Keyboard Cable: passo 24, imagem 2 %32 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Keyboard Cable: passo 24, imagem 3 %32
    • Peel the yellow tape off the black keyboard ribbon cable on the motherboard.
    • Use a spudger to slide the black tabs on either side of the connector forward slightly.
    • Pull the black ribbon straight towards you to remove it from the motherboard.
  25. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: passo 25, imagem 1 %32 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: passo 25, imagem 2 %32 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: passo 25, imagem 3 %32
    • Flip up the tabs over the two white ribbons on the left using your finger.
    • For more information on Zero Insertion Force (ZIF) connectors, please visit this guide.
    • Pull the ribbons out of the motherboard by the blue tabs.
  26. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: passo 26, imagem 1 %32
    • Using the Phillips #1 screwdriver, remove four 6 mm screws.
    • Using the same Phillips #1 screwdriver, remove five 3 mm screws securing the metal plate to the motherboard.
  27. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Remove Motherboard: passo 27, imagem 1 %32
    • Remove the metal plate over the motherboard.
    • Remove the motherboard.
  28. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Remove the LED Cable: passo 28, imagem 1 %32 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Remove the LED Cable: passo 28, imagem 2 %32
    • Flip up the latch on the cable going from the I/O board to the LED board.
  29. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: passo 29, imagem 1 %32 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: passo 29, imagem 2 %32
    • Grasp the ribbon cable and pull it straight out to the right.
  30. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Remove the Motherboard Cable: passo 30, imagem 1 %32 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Remove the Motherboard Cable: passo 30, imagem 2 %32
    • Flip up the latch on the cable from the I/O board to the motherboard.
  31. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: passo 31, imagem 1 %32 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: passo 31, imagem 2 %32
    • Grasp the ribbon cable by the blue plastic reinforcement and pull the cable straight out to the right.
  32. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Remove the Retaining Screw: passo 32, imagem 1 %32
    • Remove the single screw securing the I/O board.
  33. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: passo 33, imagem 1 %32
    • Remove the I/O board.
    • When reinstalling, be sure the hinge goes above the I/O board, not below it.
  34. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Disconnect the LED board: passo 34, imagem 1 %32 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Disconnect the LED board: passo 34, imagem 2 %32
    • Flip the retaining latch up with a spudger.
  35. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: passo 35, imagem 1 %32 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: passo 35, imagem 2 %32
    • Pull the cable straight out away from the front of the computer.
  36. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Remove the LED board: passo 36, imagem 1 %32 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Remove the LED board: passo 36, imagem 2 %32 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Remove the LED board: passo 36, imagem 3 %32
    • Remove the single retaining screw securing the LED board.
    • Remove the board.
    • When reassembling, ensure the board is seated on the guide pin before reinstalling the retaining screw.
  37. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Remove the I/O board cable: passo 37, imagem 1 %32 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Remove the I/O board cable: passo 37, imagem 2 %32 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Remove the I/O board cable: passo 37, imagem 3 %32
    • The cable between the I/O board and the motherboard is lightly adhered to the plastic insulator on the keyboard. Pull up from the right to free the cable from the adhesive.
  38. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Remove the LED cable: passo 38, imagem 1 %32 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Remove the LED cable: passo 38, imagem 2 %32
    • The LED cable runs from the LED board to the I/O daughter card. It is lightly adhered to the keyboard. Remove it by gently pulling it away from the keyboard.
  39. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Keyboard has been removed: passo 39, imagem 1 %32
    • All components have now been removed from the keyboard / palm rest assembly.
Conclusão
Jerry Wheeler
Membro desde: 03/21/22
58.506 Reputação
Autoria de 69 guias
Equipe
Oregonians Membro de Oregonians
Community
Membros da 8
Autoria de 176 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 9
Duração total: 219
