Introdução
Many Acer 15" Chromebooks use the same keyboard, including the C910, CB3-431, CB3-531, CB5-571 and possibly others, although the palm rest assembly is the same only on the CB3-531.
There are new keyboard-only replacement parts for sale, but using them requires melting off or otherwise removing the head of approximately 58 plastic retaining pins, then figuring out how to re-secure them. That kind of replacement is beyond the scope of this guide, so we'll only be dealing with a replacement that comes with a keyboard + palm rest as a single unit as pictured above.
O que você precisa
Using the Phillips #1 screwdriver, remove eighteen 7 mm screws from the back panel of the device.
Push on the sides of the connector with a plastic spudger to separate the cable from the motherboard.
Using the Phillips #1 screwdriver, remove the two black 5.5 mm screws securing the battery.
Firmly pull the end of the black wire attached to the Wi-Fi card upwards and remove it from the device.
Repeat with the white wire.
Deroute the black wifi wire from its slot in the palm rest.
Deroute the white wifi wire from the slot in the palm rest.
Pull the end of the display cable attached to the motherboard straight up to remove.
Rotate the cable out away from the motherboard.
Lift the palm rest assembly from the front then slide it away from the hinges slightly to remove the assembly from the display.
Flip up the retaining latch securing the touchpad cable to the motherboard.
Carefully lift up on the keyboard ribbon cable and the insulating sheet immediately below it so the touchpad can clear them.
Lift the touchpad slightly from the top.
Pull the touchpad toward the motherboard as you continue to lift it, sliding it out from under the retaining fingers at the bottom.
Pull the black ribbon attached to the speakers out of the motherboard.
Peel the yellow tape off the black keyboard ribbon cable on the motherboard.
Use a spudger to slide the black tabs on either side of the connector forward slightly.
Pull the black ribbon straight towards you to remove it from the motherboard.
Remove the metal plate over the motherboard.
Remove the motherboard.
Flip up the latch on the cable going from the I/O board to the LED board.
Flip up the latch on the cable from the I/O board to the motherboard.
Remove the single retaining screw securing the LED board.
Remove the board.
When reassembling, ensure the board is seated on the guide pin before reinstalling the retaining screw.
The cable between the I/O board and the motherboard is lightly adhered to the plastic insulator on the keyboard. Pull up from the right to free the cable from the adhesive.
The LED cable runs from the LED board to the I/O daughter card. It is lightly adhered to the keyboard. Remove it by gently pulling it away from the keyboard.
All components have now been removed from the keyboard / palm rest assembly.
