Introdução
Here the replacement guide for the touchpad. If you notice that clicks are not registering or the mouse won't move even though you are dragging your finger across the pad, then it may need to be replaced.
O que você precisa
Unscrew the 12 back screws, circled in red. The top 8 screws are 4.90mm x 5.71mm.
The 4 screws on the bottom are 4.81mm x 4.6mm.
Pry the casing off by running a thin tool, like an opening pick, between the over and the sides
Lift up the ribbon cord attaching the track pad to the motherboard
Unscrew the two screws holding the trackpad to the casing
Carefully lift the track pad out. It has small teeth that hook unto the casing. It is important to get those lined up and seated properly when putting back together
