Ir para o conteúdo principal
Acer Chromebook R11 Speakers Replacement
O que você precisa
  1. Acer Chromebook R11 Speakers Replacement, Battery: passo 1, imagem 1 %32
    • The back cover of the R11 is held into place using 11 screws.
    • To remove, use a screwdriver appropriate for a JIS 1 screw.
  2. Acer Chromebook R11 Speakers Replacement: passo 2, imagem 1 %32
    • Battery is located in the bottom half of the computer.
    • Unscrew the two screws holding the battery in place. There is one on each side of the battery.
  3. Acer Chromebook R11 Speakers Replacement: passo 3, imagem 1 %32
    • Slide out the ribbon that is connecting the battery to the motherboard.
    • There are 7 wires leading to it, and each is a different color of the rainbow.
    • Disconnect the keyboard ribbon located at bottom center of motherboard.
  4. Acer Chromebook R11 Speakers Replacement: passo 4, imagem 1 %32
    • Remove the battery by pulling upwards.
  5. Acer Chromebook R11 Speakers Replacement, Speakers: passo 5, imagem 1 %32 Acer Chromebook R11 Speakers Replacement, Speakers: passo 5, imagem 2 %32
    • Slide out black ribbons connecting speakers to motherboard
    • Connected on lower left-hand side of motherboard
    • When removing wires, remove gently with respect to metal clips along wires that are holding them in place.
    • Slide out white ribbon connecting keyboard to motherboard
  6. Acer Chromebook R11 Speakers Replacement: passo 6, imagem 1 %32
    • Gently pull speakers upwards
    • Adhesive is below it
Conclusão
Uma outra pessoa concluiu este guia.
Victoria May
Membro desde: 02/16/17
119 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 1-2, Kass Spring 2017 Membro de USF Tampa, Team 1-2, Kass Spring 2017
USFT-KASS-S17S1G2
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 482
