Ir para o conteúdo principal
Acer Chromebook R11 CB5-132T-C1LK LED BoardReplacement
O que você precisa
  1. Acer Chromebook R11 CB5-132T-C1LK LED BoardReplacement, Bottom Panel: passo 1, imagem 1 %32
    • Using a Phillips screwdriver, remove all eleven 7.0 mm screws from the bottom of the Chromebook.
  2. Acer Chromebook R11 CB5-132T-C1LK LED BoardReplacement: passo 2, imagem 1 %32
    • Find the seam along the edge of the device.
    • Wedge a finger into the groove and separate the panel from the device. If necessary, use a spudger.
    • The panel will still be connected to the device by internal wiring, so pull it off with some caution. It is best to flip the panel to the side once the seam has been broken.
  3. Acer Chromebook R11 CB5-132T-C1LK LED BoardReplacement, LED Board: passo 3, imagem 1 %32 Acer Chromebook R11 CB5-132T-C1LK LED BoardReplacement, LED Board: passo 3, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use the flat end of the spudger to lift the retaining flap on the LED board ZIF connector.
    • Pull the ribbon cable from the ZIF connector using tweezers.
  4. Acer Chromebook R11 CB5-132T-C1LK LED BoardReplacement: passo 4, imagem 1 %32
    • Remove the 4.5 mm Phillips screw.
    • There is a magnet near the LED chip that might attract the screw.
  5. Acer Chromebook R11 CB5-132T-C1LK LED BoardReplacement: passo 5, imagem 1 %32
    • Use tweezers to remove the LED board.
Conclusão
Alan Shan
Membro desde: 04/26/17
382 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team S23-G2, Livingston Spring 2017 Membro de Cal Poly, Team S23-G2, Livingston Spring 2017
CPSU-LIVINGSTON-S17S23G2
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 969
