Introdução
In case the camera is no longer functioning, this guide explains how to access and remove it from the Chromebook.
O que você precisa
Insert the metal spudger into the groove on the edge of the screen.
Carefully slide the spudger from one corner to another.
When there is room for a finger, remove the screen by gently lifting it out of the computer.
Um comentário
Hi Elizabeh, can you do a tutorial to change the mic on this chromebook?
There was a production batch of this chromebook that had a problem with the mic. So a lot of people could benefit from this.
Cheers!
