Introdução
Removing the battery may be necessary if the Chromebook experiences power issues or if the user wants to replace an old battery. It is important when removing the battery to unplug your device charger as well as making sure the computer is turned off. Do not place the battery near any liquids or metal devices as they may harm the battery or cause the battery to discharge.
O que você precisa
Using a Phillips screwdriver, remove all eleven 7.0 mm screws from the bottom of the Chromebook.
3 outras pessoas executaram este guia.
