Ir para o conteúdo principal
Acer Chromebook R11 CB5-132T-C1LK Battery Replacement
O que você precisa
  1. Acer Chromebook R11 CB5-132T-C1LK Battery Replacement, Bottom Panel: passo 1, imagem 1 %32
    • Using a Phillips screwdriver, remove all eleven 7.0 mm screws from the bottom of the Chromebook.
  2. Acer Chromebook R11 CB5-132T-C1LK Battery Replacement: passo 2, imagem 1 %32
    • Find the seam along the edge of the device.
    • Wedge a finger into the groove and separate the panel from the device. If necessary, use a spudger.
    • The panel will still be connected to the device by internal wiring, so pull it off with some caution. It is best to flip the panel to the side once the seam has been broken.
  3. Acer Chromebook R11 CB5-132T-C1LK Battery Replacement, Battery: passo 3, imagem 1 %32
    • Remove the two 4.5 mm Phillips screws located at the sides of the battery.
  4. Acer Chromebook R11 CB5-132T-C1LK Battery Replacement: passo 4, imagem 1 %32 Acer Chromebook R11 CB5-132T-C1LK Battery Replacement: passo 4, imagem 2 %32
    • Grip the battery connection using two plastic opening tools.
    • Carefully but firmly, pry the connector from its socket by pulling it towards the battery.
    • When reconnecting the battery to the motherboard, place the red wires closer to the edge of the device and the black wires towards the center.
  5. Acer Chromebook R11 CB5-132T-C1LK Battery Replacement: passo 5, imagem 1 %32
    • Lift the battery out by pulling upward.
Conclusão
3 outras pessoas executaram este guia.
Alan Shan
Membro desde: 04/26/17
382 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team S23-G2, Livingston Spring 2017 Membro de Cal Poly, Team S23-G2, Livingston Spring 2017
CPSU-LIVINGSTON-S17S23G2
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 24
Duração total: 4,646
