Ir para o conteúdo principal
Acer Chromebook R 11 CB5-132T-C9KK Battery Replacement
O que você precisa
  1. Acer Chromebook R 11 CB5-132T-C9KK Battery Replacement, Battery: passo 1, imagem 1 %32 Acer Chromebook R 11 CB5-132T-C9KK Battery Replacement, Battery: passo 1, imagem 2 %32
    • Turn the laptop over so that the backside is facing up.
    • Use a Phillips #0 screwdriver to remove nine screws along the perimeter of the back case.
    • Use an opening tool to pry the case around the perimeter and gently release the clips attaching the back case to the front.
    • Lift the back case off of the Chromebook.
  2. Acer Chromebook R 11 CB5-132T-C9KK Battery Replacement: passo 2, imagem 1 %32 Acer Chromebook R 11 CB5-132T-C9KK Battery Replacement: passo 2, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove two screws on either side of the battery.
  3. Acer Chromebook R 11 CB5-132T-C9KK Battery Replacement: passo 3, imagem 1 %32 Acer Chromebook R 11 CB5-132T-C9KK Battery Replacement: passo 3, imagem 2 %32
    • Use the tip of a spudger or your fingernail to flip up the small locking flap. Then, you can safely pull the cable out to disconnect the battery from the motherboard.
  4. Acer Chromebook R 11 CB5-132T-C9KK Battery Replacement: passo 4, imagem 1 %32 Acer Chromebook R 11 CB5-132T-C9KK Battery Replacement: passo 4, imagem 2 %32
    • Remove the battery from the Chromebook.
Conclusão
Uma outra pessoa concluiu este guia.
Matthew Supplee
Membro desde: 09/22/22
109 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 22
Duração total: 180
