Ir para o conteúdo principal
Acer Chromebook CB5-571-C5XU Speaker Replacement
O que você precisa
  1. Acer Chromebook CB5-571-C5XU Speaker Replacement, Bottom Case: passo 1, imagem 1 %32 Acer Chromebook CB5-571-C5XU Speaker Replacement, Bottom Case: passo 1, imagem 2 %32
    • Remove the following eighteen screws using a Phillips #0 screwdriver.
    • Make sure the Chromebook is unplugged and shut down, so no files are lost and there is no risk of electrocution.
  2. Acer Chromebook CB5-571-C5XU Speaker Replacement: passo 2, imagem 1 %32 Acer Chromebook CB5-571-C5XU Speaker Replacement: passo 2, imagem 2 %32
    • Using the flat side of the spudger, pry open the bottom case of the laptop.
    • Working from the front to the back, where it connects to the screen, proved to be the easiest way of popping the case off.
  3. Acer Chromebook CB5-571-C5XU Speaker Replacement, Battery: passo 3, imagem 1 %32
    • Using a Phillips #0 screwdriver, unscrew the screw on right side of the battery placement.
    • Be careful not to lose the screw and have a small container nearby to place it in.
  4. Acer Chromebook CB5-571-C5XU Speaker Replacement: passo 4, imagem 1 %32
    • Using a plastic opening tool, disconnect the wires connecting the battery to the motherboard.
  5. Acer Chromebook CB5-571-C5XU Speaker Replacement: passo 5, imagem 1 %32
    • Gently lift the battery out and remove it from the laptop casing.
  6. Acer Chromebook CB5-571-C5XU Speaker Replacement, Speakers: passo 6, imagem 1 %32 Acer Chromebook CB5-571-C5XU Speaker Replacement, Speakers: passo 6, imagem 2 %32
    • Use the plastic pry tool to unlatch the two tabs on either side of the black ribbon.
    • Gently slide the black ribbon out from its socket and under the white ribbon.
  7. Acer Chromebook CB5-571-C5XU Speaker Replacement: passo 7, imagem 1 %32
    • Carefully remove the smaller black ribbon from the motherboard using the opening tool.
    • Be careful when prying the connector loose, its small size can make it difficult to grasp a corner of the connector.
  8. Acer Chromebook CB5-571-C5XU Speaker Replacement: passo 8, imagem 1 %32
    • Weave the black wire connecting the two speakers out of the small metal hooks.
    • It might be helpful to take a picture of how the wire is wrapped around the hooks, as this layout is important when the wire is put back.
  9. Acer Chromebook CB5-571-C5XU Speaker Replacement: passo 9, imagem 1 %32
    • Simply lift upwards on both speakers, and they will remove from their position.
Conclusão
Uma outra pessoa concluiu este guia.
️Gaetan Charles
Membro desde: 10/26/17
119 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team S6-G1, Rockett Fall 2017 Membro de UMass Dartmouth, Team S6-G1, Rockett Fall 2017
UMASSD-ROCKETT-F17S6G1
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 158
