Ir para o conteúdo principal
Acer Chromebook CB5-571-C5XU Solid State Drive Replacement
O que você precisa
  1. Acer Chromebook CB5-571-C5XU Solid State Drive Replacement, Bottom Case: passo 1, imagem 1 %32 Acer Chromebook CB5-571-C5XU Solid State Drive Replacement, Bottom Case: passo 1, imagem 2 %32
    • Remove the following eighteen screws using a Phillips #0 screwdriver.
    • Make sure the Chromebook is unplugged and shut down, so no files are lost and there is no risk of electrocution.
  2. Acer Chromebook CB5-571-C5XU Solid State Drive Replacement: passo 2, imagem 1 %32 Acer Chromebook CB5-571-C5XU Solid State Drive Replacement: passo 2, imagem 2 %32
    • Using the flat side of the spudger, pry open the bottom case of the laptop.
    • Working from the front to the back, where it connects to the screen, proved to be the easiest way of popping the case off.
  3. Acer Chromebook CB5-571-C5XU Solid State Drive Replacement, Solid State Drive: passo 3, imagem 1 %32
    • Using the Phillips #0 Screwdriver, unscrew the single screw holding the Solid State Drive in place.
  4. Acer Chromebook CB5-571-C5XU Solid State Drive Replacement: passo 4, imagem 1 %32
    • Gently lift the Solid State Drive upwards at an angle until it stops.
    • Be careful not to lift the Solid State Drive past where it stops, or you will risk breaking the hardware.
  5. Acer Chromebook CB5-571-C5XU Solid State Drive Replacement: passo 5, imagem 1 %32
    • Pull the Solid State Drive out from the socket in the direction of the angle at which it was resting.
    • The Solid State Drive should pull out with little effort. If it is resisting, do not pull harder, as this risks damage to the part.
Conclusão
David Flint
Membro desde: 10/17/17
273 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team S6-G1, Rockett Fall 2017 Membro de UMass Dartmouth, Team S6-G1, Rockett Fall 2017
UMASSD-ROCKETT-F17S6G1
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 371
