Ir para o conteúdo principal
Acer Chromebook CB5-571-C5XU Battery Replacement
O que você precisa
  1. Acer Chromebook CB5-571-C5XU Battery Replacement, Bottom Case: passo 1, imagem 1 %32 Acer Chromebook CB5-571-C5XU Battery Replacement, Bottom Case: passo 1, imagem 2 %32
    • Remove the following eighteen screws using a Phillips #0 screwdriver.
    • Make sure the Chromebook is unplugged and shut down, so no files are lost and there is no risk of electrocution.
  2. Acer Chromebook CB5-571-C5XU Battery Replacement: passo 2, imagem 1 %32 Acer Chromebook CB5-571-C5XU Battery Replacement: passo 2, imagem 2 %32
    • Using the flat side of the spudger, pry open the bottom case of the laptop.
    • Working from the front to the back, where it connects to the screen, proved to be the easiest way of popping the case off.
  3. Acer Chromebook CB5-571-C5XU Battery Replacement, Battery: passo 3, imagem 1 %32
    • Using a Phillips #0 screwdriver, unscrew the screw on right side of the battery placement.
    • Be careful not to lose the screw and have a small container nearby to place it in.
  4. Acer Chromebook CB5-571-C5XU Battery Replacement: passo 4, imagem 1 %32
    • Using a plastic opening tool, disconnect the wires connecting the battery to the motherboard.
  5. Acer Chromebook CB5-571-C5XU Battery Replacement: passo 5, imagem 1 %32
    • Gently lift the battery out and remove it from the laptop casing.
Conclusão
To reassemble your device, follow these guidelines in reverse order.
3 outras pessoas executaram este guia.
Kenneth Bowers
Membro desde: 04/08/16
1.381 Reputação
Autoria de 7 guias
Equipe
UMass Dartmouth, Team S1-G1, Valliere Fall 2018 Membro de UMass Dartmouth, Team S1-G1, Valliere Fall 2018
UMASSD-VALLIERE-F18S1G1
Membros da 4
Autoria de 19 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 826
