Ir para o conteúdo principal
Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board Replacement
O que você precisa
  1. Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement, Acer Chromebook CB5-312T-K 8Z9 Back Cover: passo 1, imagem 1 %32 Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement, Acer Chromebook CB5-312T-K 8Z9 Back Cover: passo 1, imagem 2 %32
    • First begin by flipping the laptop on its back and having the back cover face you directly.
    • Then unscrew the ten Phillips head screws that hold down the back cover using a Phillips #0 Screw Driver.
  2. Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement: passo 2, imagem 1 %32
    • Using a plastic spudger, open the back cover and remove it from the laptop.
  3. Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement, Secondary Circuit Board: passo 3, imagem 1 %32 Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement, Secondary Circuit Board: passo 3, imagem 2 %32 Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement, Secondary Circuit Board: passo 3, imagem 3 %32
    • Identify the port that is connected to the speaker.
    • Using tweezers, separate the cable from the port.
  4. Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement: passo 4, imagem 1 %32 Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement: passo 4, imagem 2 %32
    • Find and remove the blue tape from the circuit board.
  5. Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement: passo 5, imagem 1 %32 Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement: passo 5, imagem 2 %32 Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement: passo 5, imagem 3 %32
    • Remove the black tape from the port.
  6. Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement: passo 6, imagem 1 %32 Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement: passo 6, imagem 2 %32 Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement: passo 6, imagem 3 %32
    • Identify the two Phillips screws.
    • Remove the two screws holding down the board with a J1 Phillips screwdriver.
    • Gently lift the board from the Chromebook.
Conclusão
Uma outra pessoa concluiu este guia.
2 comentários
Any ideas about where to purchase this part? I am almost certain that it is the problem with my sound. Also, I can get to it no problem, but I am struggling finding a replacement part.
littlemas2 - Responder
I have looked on numerous pages on google, both with the part number and with the Chromebook model number and have yet to be able to find a supplier.
littlemas2 -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 655
